[mapserver-users] Problems rendering postgis points layer
Dave Potts dave.potts at pinan.co.uk
Sat Jan 21 04:15:07 EST 2012
Hi
I am having problems getting Mapserv 6.0.1 to render a points layer from a
postgres 8.4.10 database.  The same table renders correctly in qgis.
Mapserv can load and render a data of type 'LINE' from a postgis table.
It just seems to have problems with the 'POINT' data.
Turning the debug information on, its possible to mapserv loading my
layers streets and  one_way_from, but there is not trace of an attempt to
points layer.
So mapserver can see postgis, the post gis has the right data in, does
anybody have any idea what the problem is?
[Sat Jan 21 09:25:53 2012].480878 msPostGISLayerOpen called: the_geom from
(select route_id, the_geom from route_table) as foo using SRID=3857 using
unique route_id
[Sat Jan 21 09:25:53 2012].480885 msPostGISLayerOpen: No connection in
pool, creating a fresh one.
[Sat Jan 21 09:25:53 2012].491702 msConnPoolRegister(streets,user=demo
dbname=route-example host=127.0.0.1 port=5432,0x21364a0)
[Sat Jan 21 09:25:53 2012].498141 msPostGISLayerOpen: Got PostGIS version
10500.
[Sat Jan 21 09:25:53 2012].498163 msPostGISLayerFreeItemInfo called.
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120121/520b7b56/streets.obj
