[mapserver-users] Re: GetFeature find data with GET, not with POST
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Tue Jan 24 13:42:12 EST 2012
All I know for sure is that BBOX filter send with POST does not find data but KVP BBOX does if native Mapserver shapefile reader is used. I can repeat this with some queries I have saved. I have not yet tested the same BBOX written inside OGC <Filter> and sent url-encoded with http GET. Therefore I can not actually say if the problem has to do with POST at all, it may also be that it is the Filter Encoded BBOX that fails.
I will do more tests for isolating the problem but OGC filters are very unfriendly beasts to write and url-encoding them before they can be sent through http GET makes it even more complicated. Let's hope someone finds easy explanation for the problem soon and I can stop testing :)
-Jukka-
________________________________________
Lähettäjä: Lime, Steve D (DNR) [Steve.Lime at state.mn.us]
Lähetetty: 24. tammikuuta 2012 20:19
Vastaanottaja: Rahkonen Jukka; 'mapserver-users at lists.osgeo.org'
Aihe: RE: GetFeature find data with GET, not with POST
So GET works against the shapefile but a POST against the same shapefile doesn't? That is odd.
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Rahkonen Jukka
Sent: Tuesday, January 24, 2012 12:12 PM
To: 'mapserver-users at lists.osgeo.org'
Subject: [mapserver-users] Re: GetFeature find data with GET, not with POST
I will need to play a bit with the data and see if I can decrease the size of source layer and still see the failure. What I have now as source is one single shapefile with 1.1 million polygons and it is odd that from some areas Mapserver does find data. It looks like the problem occur on dense areas with lots of polygons. I thought first that it must be due to old or invalid index but the situation is the same with a brand new .qix file and if I do not .qix at all.
-Jukka Rahkonen-
Steve D (DNR) wrote:
> I'd say yes to a ticket if it's possible to create a concise test dataset. Usually shapefiles are the most robust > simply because they are used the most.
Steve
Sent: Tuesday, January 24, 2012 9:36 AM
Tried to use
 CONNECTIONTYPE OGR
 CONNECTION "path_to_shape"
Instead of
DATA "path_to_shape"
Now both GET and POST works with BBOX. Something seems to be wrong or undocumented with the native shapefile access. Is this worth filing some kind of ticket?
-Jukka Rahkonen-
Rahkonen Jukka  wrote:
This GetFeature finds data from MS 6.0.1 (MS4W)
service=wfs&version=1.1.0&request=getfeature&typename=peltolohkot&BBOX=280009,6696093,282161,6698297,EPSG:3067<https://ilmakuva.mmm.fi/cgi-bin/wfs_test?service=wfs&version=1.1.0&request=getfeature&typename=peltolohkot&BBOX=280009,6696093,282161,6698297,EPSG:3067>
This POST request which should find the sama data does not find anything:
<wfs:GetFeature handle="GeoTools 2.7-RC2 WFS DataStore" maxFeatures="100"
outputFormat="text/xml; subtype=gml/3.1.1" resultType="results" service="WFS"
version="1.1.0" xmlns:ogc="http://www.opengis.net/ogc" xmlns:gml="http://www.
opengis.net/gml" xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:ows="http://www.opengis.net/ows" xmlns:wfs="http://www.opengis.
net/wfs"><wfs:Query srsName="EPSG:3067"
typeName="peltolohkot"><ogc:Filter><ogc:BBOX><ogc:PropertyName>msGeometry</ogc:PropertyName><gml:Envelope><gml:lowerCorner>280009.0 6696093.0
</gml:lowerCorner><gml:upperCorner>282161.0 6698297.
0</gml:upperCorner></gml:Envelope></ogc:BBOX></ogc:Filter></wfs:Query></wfs:GetFeature>
Mapserver log file does not tell anything interesting, just this
msQueryByFilter(): Search returned no results. No matching record(s) found.
Data is as shapefile. I have the same dataset in PostGIS on another computer and with that service the filter above does find features. Could this possibly have something to do with the shapefile/PostGIS difference?
-Jukka Rahkonen-
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
