[mapserver-users] Re: getSymbol (): Symbol definition error.
Francesc Cañas kikocanas at gmail.com
Fri Jan 27 04:08:12 EST 2012
Ok, at first, thanks for helping me,
But I feel lost, this is never ending story.
I've removed all cartoline in the symbols.sym, I've removed the OUTPUTFORMAT
block entirely but now i have a new error message:
Content-type: text/html msReturnPage(): Web application error. Malformed
template name (fooOnlyForWMSGetFeatureInfo)
I thing maybe is because I didn't change the BROWSEFORMAT, so I do
BROWSEFORMAT  "image/png".
For the fist time the screen don't display an error message, but don't
display anything at all.
The code now is like this:
# Map file created from QGIS project file
C:/Users/Francesc/Documents/Projectes_CAT_wgs.qgs
# Edit this file to customize for your map interface
# (Created with PyQgis MapServer Export plugin)
MAP
  NAME "Projectes Cat"
  SIZE 100 100
  UNITS dd
  IMAGETYPE png
  EXTENT -9.569062 32.926808 6.763360 44.857479
  FONTSET 'C:/Users/Francesc/Documents/font/fonts.txt'
  SYMBOLSET 'C:/Users/Francesc/Documents/symbols/symbols.sym'
  PROJECTION
    'proj=longlat'
    'datum=WGS84'
    'no_defs'
  END
  # Background color for the map canvas -- change as desired
  IMAGECOLOR 255 255 255
  # Legend
  LEGEND
    STATUS ON
    KEYSIZE 18 12
    LABEL
      TYPE BITMAP
      SIZE MEDIUM
      COLOR 0 0 89
    END
  END
  # Web interface definition. Only the template parameter
  # is required to display a map. See MapServer documentation
 WEB
    # Set IMAGEPATH to the path where MapServer should
    # write its output.
    IMAGEPATH 'G:/Francesc/ms4w/tmp'
    # Set IMAGEURL to the url that points to IMAGEPATH
    # as defined in your web server configuration
    IMAGEURL 'G:/Francesc/ms4w/tmp'
    # WMS server settings
    METADATA
      'ows_title'           'Projectes Cat'
      'ows_onlineresource'
'http://localhost/cgi-bin/mapserv.exe?map=C:/Users/Francesc/Documents/Projectes_wgs84_v6.map'
      'ows_srs'             'EPSG:4326'
    END
    #Scale range at which web interface will operate
    # Template and header/footer settings
    # Only the template parameter is required to display a map. See
    TEMPLATE 'fooOnlyForWMSGetFeatureInfo'
  END
  LAYER
    NAME 'Provincias_wgs84'
    TYPE POLYGON
    DUMP true
    TEMPLATE fooOnlyForWMSGetFeatureInfo
    DATA 'C:/Users/Francesc/Documents/SHP/Provincias_wgs84.shp'
    METADATA
      'ows_title' 'Provincias_wgs84'
    END
    STATUS OFF
    TRANSPARENCY 100
    PROJECTION
    'proj=longlat'
    'datum=WGS84'
    'no_defs'
    END
    CLASS
       STYLE
         WIDTH 0.35
         OUTLINECOLOR 0 0 0
       END
    END
  END
  LAYER
    NAME 'Projectes_UTM31_wgs84'
    TYPE POINT
    DUMP true
    DATA 'C:/Users/Francesc/Documents/SHP/Projectes_UTM31_wgs84.shp'
    METADATA
      'ows_title' 'Projectes_UTM31_wgs84'
    END
    STATUS OFF
    TRANSPARENCY 100
    PROJECTION
    'proj=longlat'
    'datum=WGS84'
    'no_defs'
    END
    CLASS
       STYLE
         SYMBOL "circle"
         SIZE 7.0
         OUTLINECOLOR 0 0 0
         COLOR 103 132 169
       END
    END
  END
END
View this message in context: http://osgeo-org.1560.n6.nabble.com/getSymbol-Symbol-definition-error-tp4340534p4342552.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
