[mapserver-users] Mapserver and TileCache,
parsing error thereby no cached images
Michael Markieta
markieta.m at gmail.com
Mon Jan 30 00:25:11 EST 2012
Hi all,
Original question was posted here:
http://gis.stackexchange.com/questions/19459/tilecache-and-mapserver-not-producing-images-and-raising-parsing-error
Just a forewarning, I will try to be as extensive with my question as
possible. Due to a number of reasons why this might not be working, I have
posted all sorts of portions of my debugging below.
Web map located here <http://rinnerweb.arts.ryerson.ca/moot2_dev>
Tile cache is being setup as a test run for the "hii_5" layer in
OpenLayers. MapServer is the backend.
I am trying to get TileCache to cache images of my MapServer WMS. However,
no images are produced. The TileCache is "trying" to load the tiles (as you
can see on the live page), however, no images are returned.
When I follow the
path<http://rinnerweb.arts.ryerson.ca/cgi-bin/tilecache.cgi?LAYERS=HII_railroads&FORMAT=image/png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG:3857&BBOX=-10592586.767623,5113378.756775,-9340242.496373,6365723.028025&WIDTH=256&HEIGHT=256>of
one of the image tiles, I see this error:
An error occurred: File contains parsing errors:
C:\ms4w\Apache\cgi-bin\tilecache.cfg
[line 82]: ' type=WMS\n'
[line 83]: ' url=http://141.117.104.183/cgi-bin/mapserv.exe\n'
[line 84]: ' mapfile=C:/ms4w/Apache/htdocs/moot2_dev/hii_railroads.map\n'
[line 85]: ' extension=png\n'
[line 86]: ' layers=HII_railroads\n'
File "C:\ms4w\Apache\cgi-bin\TileCache\Service.py", line 85, in _load
config.read(files)
File "C:\Python27\lib\ConfigParser.py", line 297, in read
self._read(fp, filename)
File "C:\Python27\lib\ConfigParser.py", line 538, in _read
raise e
- I've run a
GetCapabilities<http://rinnerweb.arts.ryerson.ca/cgi-bin/mapserv.exe?map=/ms4w/apache/htdocs/moot2_dev/hii_railroads.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities>request
and there are no warnings
- but GetMap<http://rinnerweb.arts.ryerson.ca/cgi-bin/mapserv.exe?map=/ms4w/apache/htdocs/moot2_dev/hii_railroads.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=HII_railroads&STYLES=&SRS=EPSG:3857&BBOX=-173.537,35.8775,-11.9603,83.8009&WIDTH=400&HEIGHT=300&FORMAT=image/png>request
returns a blank page
- and the template<http://rinnerweb.arts.ryerson.ca/cgi-bin/mapserv.exe?map=/ms4w/Apache/htdocs/moot2_dev/hii_railroads.map&>return
blank
Here are the relevant mapfile, tilecache.cfg, and openlayers source:
Not sure how much help I will get here, but the questions out there for
anyone to take a stab at it!
*hii_railroads.map*
MAP #-> BEGIN MAP
OUTPUTFORMAT #-> BEGIN
OUTPUT FORMATTING DEFINITION
NAME "png" # Name of format
DRIVER AGG/PNG # Image driver
MIMETYPE "image/png" # Type of image
IMAGEMODE RGBA # Image mode
EXTENSION "png" # Image filetype
TRANSPARENT ON # Transparency
END #-> END OUTPUT
WEB #-> BEGIN WEB DEFINITION
METADATA
"wms_title" "HII_railroads"
"wms_onlineresource"
"http://rinnerweb.arts.ryerson.ca/cgi-bin/mapserv.exe?map=/ms4w/Apache/htdocs/moot2_dev/hii_railroads.map&"
"wms_srs" "EPSG:3857"
"ows_enable_request" "*"
END
TEMPLATE "template.html"
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
END #-> END WEB DEFINITION
LAYER #-> BEGIN
LAYER DEFINITION: Railroads <-#
METADATA
END
NAME HII_railroads # Layer identifier
DATA "data/wgs84/railroads_360.tif" # Name of the
data (in this case, string identifying a raster)
STATUS ON
*tilecache.cfg*
[HII_railroads]
type=WMS
extension=png
*index.html*
hii_5 = new OpenLayers.Layer.WMS("Railroads","../../cgi-bin/tilecache.cgi?",{
layers:"HII_railroads",
format:"image/png"},{
isBaseLayer:false,
transparent:true,
format:"image/png",
alpha:true,
displayInLayerSwitcher:false
Michael Markieta - (416) 833 5581
Research Assistant - Department of Geography &
Bachelor of Arts Candidate - Geographic Analysis
Ryerson University
Toronto, ON, Canada
www.spatialanalysis.ca
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120130/8086b080/attachment.html
