[mapserver-users] Problem querying personal GDB
Brent Fraser
bfraser at geoanalytic.com
Tue Jul 3 15:01:03 PDT 2012
Bob,
You may need to add a "using unique" clause like "using unique gid"
http://www.mapserver.org/input/vector/postgis.html#data-access-connection-method
Best Regards,
Brent Fraser
On 7/3/2012 2:12 PM, Bistrais, Bob wrote:
> Please excuse me if this is redundant- I've also posted this to the
> GeoMoose list, and I can't remember what I've posted where on this issue.
> I am building an application with MapServer 6.0.2, and GeoMoose 2.6 on
> the front end. One of the layers is contained in an ESRI personal
> Geodatabase, i.e. a Microsoft Access database.
> This layer displays properly. I can also do an Identify on it and get
> expected results. It's when I try to do a Search (a select by
> attributes) when things fall apart. Checking the error log, I see
> msEvalExpression(): General error message. Cannot evaluate
> expression, no item index defined.
> It's also worth noting that, if I convert the layer to shapefile and
> use that in the application, it will work. But there's a few
> operational considerations that make it preferable to use the GDB. So
> the problem seems to be with querying the MDB. Does anyone have any
> ideas?
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120703/57d1164a/attachment-0001.html>
