[mapserver-users] wms_bbox_extended "true" only works with < 15 EPSG code definitions
Astrid Emde
astrid.emde at wheregroup.com
Tue Jul 17 14:26:39 PDT 2012
Hello,
I want to use the Parameter wms_bbox_extended "true" to calculate the
extent for all the supported EPSGs.
see
http://mapserver.org/ogc/wms_server.html
The Capabilities document looks fine as long as I only define < 15 codes.
The XML breaks at different points with more EPSG codes (but I need > 15
for INSPIRE)
Definition could look like this:
WEB
WMS_BBOX_EXTENDED 'true'
WMS_SRS 'EPSG:31466 epsg:31467 epsg:31468 epsg:4326 EPSG:25832
EPSG:25833 EPSG:3034 EPSG:3035 EPSG:3038 EPSG:3039 EPSG:3040 EPSG:3041
EPSG:3042 EPSG:3043 EPSG:3044 EPSG:3045 EPSG:3046 EPSG:3047'
END
When I disable the parameter wms_bbox_extended "false" (or I do not define
the parameter) the Capabilities XML is fine, but does not contain the
bboxes.
I tested with MapServer 6.0.2 and MapServer 6.2beta1.
I also created a bug ticket at github
https://github.com/mapserver/mapserver/issues/4395
It is not an urgent issue. Just wanted to notice it.
Astrid
