[mapserver-users] On the fly Projection
Sowmya Tiramdasu
stiramdasu at qcoherent.com
Thu Jul 26 12:51:56 PDT 2012
Hi Jeff,
Thanks for the references you provided . I gave the output projections
under the MAP section and the LAYER Projection under the layer section. But
I am not sure what is the error. The projection is not happening correctly.
I do not see any specific errors in the log file also.
Below are the details of my two different shape files. I want the
SBET_Trajectory_source to be projected in to the Photogrammetric_point's
projection.
Layer name: Photogrammetric_Point
Geometry: 3D Point
Feature Count: 33
Extent: (1532496.038000, 197080.590000) - (1543965.215000, 203467.824241)
Layer SRS WKT:
PROJCS["NAD_1983_StatePlane_Kentucky_North_FIPS_1601_Feet",
GEOGCS["GCS_North_American_1983",
DATUM["North_American_Datum_1983",
SPHEROID["GRS_1980",6378137,298.257222101004]],
PRIMEM["Greenwich",0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["False_Easting",1640416.66666667],
PARAMETER["False_Northing",0],
PARAMETER["Central_Meridian",-84.25],
PARAMETER["Standard_Parallel_1",37.9666666666667],
PARAMETER["Standard_Parallel_2",38.9666666666667],
PARAMETER["Latitude_Of_Origin",37.5],
UNIT["Foot_US",0.304800609601219]]
Desc: String (254.0)
EntityType: String (254.0)
EntTypDesc: String (254.0)
GUID: String (254.0)
LyrName: String (254.0)
LyrDesc: String (254.0)
CentroidX: Real (18.9)
CentroidY: Real (18.9)
CentroidZ: Real (18.9)
C:\ms4w\tools\gdal-ogr>ogrinfo
C:\ms4w\apps\tutorial\data\SBET_Trajectory_Source
.shp SBET_Trajectory_Source -summary
INFO: Open of `C:\ms4w\apps\tutorial\data\SBET_Trajectory_Source.shp'
using driver `ESRI Shapefile' successful.
Layer name: SBET_Trajectory_Source
Geometry: 3D Line String
Feature Count: 1
Extent: (-84.760205, 37.880771) - (-84.333587, 38.208327)
Layer SRS WKT:
NumVerts: Real (11.0)
EntLength: Real (18.9)
LengthUnit: String (254.0)
The projections I mentioned in my mapfile are :
The output projection : PROJECTION
"proj=utm"
"zone=17"
"ellps=WGS84"
"datum=WGS84"
"units=m"
"no_defs"
END
SBET_Trajectory_Source projection : PROJECTION
"proj=longlat"
"ellps=GRS80"
"datum=NAD83"
"no_defs"
END
Can you identify where I am going wrong ? I am kind of stuck , don't have
any clues why it is not working. Thanks again for all your time and patience
in helping me.
Thanks,
Sowmya.
_______________________________
Sowmya Tiramdasu
QCoherent Software
9668 Madison Blvd., Suite 202
Madison, AL 35758
(256) 461-8289 Telephone
(256) 461-8249 Fax
www.geocue.com
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
Sent: Thursday, July 26, 2012 10:03 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] On the fly Projection
Hello Sowmya,
A really helpful site for searching for projections and then different
syntax examples for them is: http://spatialreference.org
Yours might be here: http://spatialreference.org/ref/sr-org/15/
Have fun!
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 12-07-26 11:22 AM, Sowmya Tiramdasu wrote:
> Hi,
> I have a projection given as follows :
GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS
_1980",6378137,298.257222101004]],PRIMEM["Greenwich",0],UNIT["Degree",0.0174
532925199433]]
> How can I specify this under the PROJECTION in mapfile and also I would
> like to project this on to epsg : 32617. How can I achieve this.
> Any help will be appreciated. Thanks in advance!
> Thanks,
> Sowmya.
> *_______________________________*
> Sowmya Tiramdasu
> *QCoherent Software*
> Madison, AL 35758
> (256) 461-8249 Fax
> www.geocue.com <http://www.geocue.com/>
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
