[mapserver-users] MapCache - A way to delete a whole zoom level ?
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Jun 4 07:20:28 PDT 2012
Ludovic' problem is that he is out of disk space so that is probably not
going to work for him. If he can not free some space to start with it is
likely he will have to delete the whole cache.
Ludovic, You might want to write an enhancement request to mapcache,
that requests each zoom level be put into a separate database file so
that it is easy to monitor the disk space each zoom level uses and to
quickly remove a zoom level with a system level file delete.
-Steve W
On 6/4/2012 9:22 AM, Rahkonen Jukka wrote:
> Hi,
> Just guessing without knowing anything about Berkeley DB, but if it
> is like other databases it would probably need vacuuming after delete
> before it really frees any disk space. And if you do mass delete and
> Berkeley DB behaves even closely similarly than SQLite, vacuuming may
> be extremely slow. In that case if might be faster to copy everything
> that has remained in the old database into a new database but with
> zillions of tiles that can take a long time too. But as I said, I am
> just guessing.
> -Jukka Rahkonen-
> Ludovic Gnemmi wrote:
>> Hi Alan, I'm using Berkeley DB cache type so i haven't any
>> directory. No errors. I'v just checked my bdb.db file which still
>> has the same size :( Ludovic
>> -- View this message in context:
>> http://osgeo-org.1560.n6.nabble.com/MapCache-A-way-to-delete-a
>> -whole-zoom-level-tp4978491p4978968.html Sent from the Mapserver -
>> User mailing list archive at Nabble.com.
>> _______________________________________________ mapserver-users
>> mailing list mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
