[mapserver-users] Circles around points in miles
Ian Walberg
ian.walberg at airborne.aero
Mon Jun 11 09:37:18 PDT 2012
Steve,
Below is a map file with the settings we are using.
The Extent and projection are commented out for the test.
With the projection set to "init=epsg:4326" the circles appear the size
we expect.
With projection set to "proj=orth" and the extent changed to EXTENT
-200000 -200000 200000 200000 all the other data (removed form this map
file for simplicity) appears ok and the circles disappear.
Thanks
Ian
MAP
NAME 'Simple'
STATUS ON
SIZE 1280 768
EXTENT -121 34 -115 41
# EXTENT -200000 -200000 200000 200000
UNITS DD
SHAPEPATH "shp"
IMAGECOLOR 120 120 120
SYMBOL
NAME 'circle2'
TYPE ELLIPSE
POINTS 1 1 END
FILLED FALSE
END
LAYER
DEBUG 5
NAME range_circles
TYPE point
STATUS DEFAULT
UNITS miles
SIZEUNITS miles
FEATURE
POINTS
-118 38
END
END
CLASS
STYLE
MAXWIDTH 1
SYMBOL 'circle2'
SIZE 50
COLOR 255 0 0
END
STYLE
MAXWIDTH 1
SYMBOL 'circle2'
SIZE 100
COLOR 255 0 0
END
STYLE
MAXWIDTH 1
SYMBOL 'circle2'
SIZE 150
COLOR 255 0 0
END
END
PROJECTION
"proj=latlong"
"ellps=WGS84"
"datum=WGS84"
END
END
PROJECTION
"init=epsg:4326"
# "proj=ortho"
"lat_0=38.0"
"lon_0=-118"
"ellps=WGS84"
END
END
-----Original Message-----
From: Lime, Steve D (DNR) [mailto:Steve.Lime at state.mn.us]
Sent: Monday, June 11, 2012 7:45 AM
To: Ian Walberg; mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] RE: Circles around points in miles
What are the UNITs set to with "proj=ortho"?
From: Ian Walberg [mailto:ian.walberg at airborne.aero]
Sent: Friday, June 08, 2012 7:19 PM
To: mapserver-users at lists.osgeo.org
Cc: Lime, Steve D (DNR)
This question from earlier in the year has finally got to the top of our
to do list.
The issue is how to draw a circle at a given size (ideally in miles)
when using "proj=ortho".
Everything works well when using "proj=latlong" and SIZEUNITS miles.
Is this the expected behaviour and we do not understand something or is
this a problem?
Many thanks
Ian
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ian
Walberg
Sent: Thursday, February 16, 2012 1:57 PM
This does not work in all cases as we hoped, or we may not understand
how to use the overall ma projection correctly.
All the layers have the projection set to "proj=latlong,ellps=WGS84".
However if we set the overall map projection from this to "proj=ortho"
the layer with the sizeunits set disappears.
Is this an issue related to the projection or that the map units are now
different.
If we remove the sizeunits from the layer with the circles they reappear
but of course are not the correct size (in miles).
Many thanks
Ian
Sent: Wednesday, February 15, 2012 11:40 AM
To: Stephen Woodbridge; mapserver-users at lists.osgeo.org
Stephen,
That appears to do the trick.
Many thanks
Ian
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephen
Woodbridge
Sent: Wednesday, February 15, 2012 10:36 AM
Subject: Re: [mapserver-users] RE: Circles around points in miles
On 2/15/2012 1:23 PM, Ian Walberg wrote:
> Steve,
> Thanks again for the info so far.
> Testing this today we realise (not surprisingly) that both the size
> and width of the symbol are now in miles.
> Ideally we would like to set the radius of the circle in miles and the
> width in pixels.
> Is there any way of doing this?
Yes, add minwidth 1 and maxwidth 1 to force the width to 1 pixel.
-Steve W
> Regards
> Ian
> Sent: Monday, February 13, 2012 2:57 PM
> Subject: RE: Circles around points in miles
> I jumped the gun on the geomtransform idea. The support is there but
> because it operates at the style level buffer distances must be given
> in pixels and there's no easy way to convert a map distance (e.g. 10
> miles) to pixels. I really should make some runtime constants (for
> example, extent, scale and cellsize) available to expressions- then
> you could do this.
> Glad you picked option 2 to start.
> Steve
> Sent: Monday, February 13, 2012 4:38 PM
> To: Lime, Steve D (DNR); mapserver-users at lists.osgeo.org
> Steve,
> Many thanks for the help and we have just tested option 2 and that
> works.
> We are using 6.x but are not exactly sure how to use the geomtransform
> to do this. Do you have an example?
> Regards
> Ian
> Sent: Monday, February 13, 2012 9:37 AM
> Couple of options depending on version:
> 1) 6.x: buffer the points using a style geomtransform
> 2) all versions: use layer SIZEUNITS to draw a circle symbol in
> miles
> I think option 1 is more flexible but option 2 is probably faster.
> Steve
> From: mapserver-users-bounces at lists.osgeo.org
> Walberg
> Sent: Saturday, February 11, 2012 10:06 PM
> Subject: [mapserver-users] Circles around points in miles
> We need to draw circles of 50 and 100 miles around a list of points.
> How can we do this?
> Thanks
> Ian
