[mapserver-users] making pgrouting shortest distance function run with mapserver
Annu Anurag i.skidoosh at gmail.com
Mon Jun 11 20:30:38 PDT 2012
Yes sir. That worked. But I'm still getting an error:
msDrawMap(): Image handling error. Failed to draw layer named 'route'.
msPostGISLayerWhichShapes(): Query error. Error executing query: ERROR:
column "source" does not exist LINE 1: SELECT gid AS id, source::int4,
target::int4, length::double... ^ QUERY: SELECT gid AS id, source::int4,
target::int4, length::double precision AS cost FROM edges_line
The error log contains this:
[Tue Jun 12 08:54:34 2012].554731 msPostGISLayerWhichShapes query: select
encode(ST_AsBinary(ST_Force_2D("the_geom"),'NDR'),'hex') as geom,"gid" from
(select b.gid, b.the_geom FROM (SELECT * FROM shortest_path('SELECT gid AS
id, source::int4, target::int4, length::double precision AS cost FROM
edges_line', 50, 210, false, false)) as a, edges_line as b where
a.edge_id=b.gid) AS foo where the_geom &&
GeomFromText('POLYGON((-6015.80966101695 -4605.49,-6015.80966101695
4811.71,6544.54966101695 4811.71,6544.54966101695
-4605.49,-6015.80966101695 -4605.49))',-1)
[Tue Jun 12 08:54:34 2012].568295 msPostGISLayerWhichShapes query status:
PGRES_FATAL_ERROR (7)
[Tue Jun 12 08:54:34 2012].568405 Error (msPostGISLayerWhichShapes()
) executing query: ERROR:  column "source" does not exist
LINE 1: SELECT gid AS id, source::int4, target::int4, length::double...
QUERY:  SELECT gid AS id, source::int4, target::int4, length::double
[Tue Jun 12 08:54:34 2012].568478 msPostGISLayerWhichShapes(): Query error.
Error executing query: ERROR:  column "source" does not exist
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120612/e0c048a5/attachment.html>
