[mapserver-users] Mapscript Java Interface for 64 Bit Java Version?
Tamas Szekeres
szekerest at gmail.com
Wed Jun 13 00:11:52 PDT 2012
Hi Umberto,
If you have msvc installed, you can use the corresponding sdk package (from
this site) to do a command line build. For details see the readme file.
Best regards,
Tamas
2012/6/13 Umberto Nicoletti <umberto.nicoletti at gmail.com>
> Tamas, thanks for the link.
> Recently I was working on:
> https://github.com/mapserver/mapserver/issues/4231
> and had some trouble with Windows builds because I simply don't have a
> build env for Windows and had to ask jmckenna to pull and build for me.
> So I ended up with a gcc only fix.
> Any chance that I can use the build tools ot that link so that I can fix
> the issue for Windows too?
> Cheers,
> Umberto
> On Wed, Jun 13, 2012 at 9:01 AM, Tamas Szekeres <szekerest at gmail.com>wrote:
>> Jacob,
>> As far as I remember the gisinternals build server compiles java
>> mapscript for x64.
>> http://www.gisinternals.com/sdk/
>> Best regards,
>> Tamas
>> 2012/6/11 Jacob Mendt <Jacob.Mendt at mailbox.tu-dresden.de>
>>> Hello List.****
>>> I appreciate the work which is done around the mapserver. Right now I
>>> try to use the java mapscript interface and I got the following issue.**
>>> I already got the java mapscript interface running. But right now it is
>>> only working with a 32-bit java version. My question is now, if there is
>>> also any support for 64-bit java version? ****
>>> My runtime environment is:****
>>> - Windows 7 (64 bit)****
>>> - MS4W v3.0.2 packet (Mapscript 5.6.6.)****
>>> - Java Version: 1.7.0_0.4 (32-bit)****
>>> I am looking forward to hear from you.****
>>> Kind regards,****
>>> JM****
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120613/d090f5fc/attachment.html>
