[mapserver-users] Map Not Available at This Scale Image
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Thu Jun 14 15:16:24 PDT 2012
Why not a layer with STATUS DEFAULT but a MAXSCALE value that kicks in when your other data runs out?
From: Donald Kerr [mailto:donald.kerr at dkerr.co.uk]
Sent: Thursday, June 14, 2012 4:07 PM
To: Lime, Steve D (DNR); 'MAPSERVER USERS'
Subject: RE: [mapserver-users] Map Not Available at This Scale Image
Steve,
I don't think that any of those options will work for me. I have fifteen zoom levels and the map coverage is complete except for three. Those three are a made up of an image returned after querying PostGIS so a blank image is effectively created since there are no points, lines or polygons returned from the PostGIS query at that zoom level i.e. to all intents and purposes, a valid map is returned except that there's noting in it. It's these particular zoom levels where I am trying to display the "no coverage' message. I had thought that it may be possible to create a permanent layer that's always there under all the layers and is effectively overwritten by any drawn layers above except where there's no data. I'm thinking now that this may not be possible.
Many thanks.
Regards,
Donald
-----Original Message-----
From: Lime, Steve D (DNR) [mailto:Steve.Lime at state.mn.us]
Sent: 14 June 2012 21:54
To: Donald Kerr; 'MAPSERVER USERS'
Couple of options.
1)      You can create a layer that displays that text in the middle of the map and have it turn on below a certain scale. If doing tiling w/meta-tiling you'd want draw the text the same number of times as you have meta-tiles. That would take some mucking about but it's doable.
2)      There's a little used parameter in the WEB section called MINTEMPATE/MAXTEMPLATE. MapServer will redirect to the URL specified depending on scale. It's been ages since I used it but in theory you could reference an image with the necessary text by URL.
Steve
From: mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Donald Kerr
Sent: Thursday, June 14, 2012 1:42 PM
To: 'MAPSERVER USERS'
Subject: [mapserver-users] Map Not Available at This Scale Image
Hi list,
I have a number of layers that are on or off depending on the zoom level and some of those layers do not have coverage in certain areas. The question is, is there a way to display a map image saying something along the lines of, "Map not available at this level"?
I think I have read somewhere that it can be done in a round about way but I cannot find any information after having a good internet trawl.
Many thanks.
Regards,
Donald
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120614/b8a9bc14/attachment.html>
