[mapserver-users] GRID - how to display labels not in degrees
Alexandre Dube
adube at mapgears.com
Wed Jun 20 12:16:44 PDT 2012
Hey Jeff,
Yes, it worked without setting any interval, but that made me realize
my mistake. The interval values are in degrees when using 4326, so
switching to 900913 they must be in meters. Setting them to more proper
values, such as 1000000 instead of 2 did the trick. It works fine.
Thanks,
Alexandre
On 12-06-20 02:41 PM, Jeff McKenna wrote:
> On 12-06-20 2:30 PM, Alexandre Dube wrote:
>> Hi,
>> Using the [GRID] object, I'm able to do a GetMap request using
>> &SRS=EPSG:900913 to display a the grid correctly reprojected, but the
>> coordinates displayed (labels) are in degrees. When switching the layer
>> PROJECTION from 4326 to 900913, the request throws a 504 error.
>> How can I display them in 900913 ?
>> See the attached image and layer definition. I'm using MapServer 6.0.1.
> Hello Alexandre,
> If I was in this situation I would:
> - try to duplicate it with an easy shp2img command (I can locally, using
> gmap75 mapfile and setting the projection of the grid layer to 3978
> instead of 4326)
> - then, once you get that crash with that easy command (yup I get the
> crash with MS 6.0.3), I would start to comment all those parameters in
> your actual GRID object
> - for me, I found that once I commented the M*INTERVAL parameters I was
> able to get a valid map image with grid lines nicely labelled in meters
> I think there is a ticket/issue here so I think it would be nice to
> package a little test case that throws this crash.
> Happy first day of summer! (or the best 5-à-7 day of the year!)
> -jeff
Alexandre Dubé
Mapgears
www.mapgears.com
