[mapserver-users] mapcache - is it possible to access different wms sources based on the current resolution or scale?
Eichner, Andreas - SID-NLKM Andreas.Eichner at sid.sachsen.de
Wed Jun 27 03:10:12 PDT 2012
If the grid matches, you can easily symlink the zoom levels.
HTH
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag
> von Mark Volz
> Gesendet: Dienstag, 26. Juni 2012 23:28
> An: MapserverList OSGEO
> Betreff: [mapserver-users] mapcache - is it possible to
> Hello,
> I would like to use mapcache to cache two layers.  The first
> is a basemap that displays a political map when zoomed far
> out, or an air photo depending when zoomed in.  The second
> layer displays that same air photo, but at all zoom levels.
> Is there any way to conserve disk space so the two layers
> share the same physical cache when zoomed in?
> Thanks
> Mark Volz
> GIS Specialist
