[mapserver-users] undesired pattern with getLegendGraphic
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Fri Jun 29 07:54:40 PDT 2012
My problem is with the CLASS of a WMS layer. Using Cascading
GetLegendGraphic I get the legend defined on the server side, a triangle
with a label. But I don't want to use this legend so I created a CLASS
definition for the layer so I get only a triangle.
But instead of returning a single triangle, I get several triangles in the
image. See attached files
I can't find what can cause this behavior.
Here is the symbol definition and the mapfile
SYMBOL
        NAME    'triangle'
        TYPE    VECTOR
        FILLED  TRUE
        POINTS
                0       1
                .5      0
                1       1
                0       1
        END
END
LAYER
NAME "fire"
TYPE RASTER
STATUS ON
CONNECTION "http://.../cgi-wms/mapserv?map=fire"
CONNECTIONTYPE WMS
METADATA
        "wms_srs"             "EPSG:900913"
        "wms_name"            "fire"
        "wms_title"           "fire"
        "wms_server_version"  "1.1.1"
        "wms_format"          "image/png"
END
CLASS
        NAME "fire"
        STYLE
                SYMBOL  "triangle"
                SIZE 15
                COLOR 178 34 34
                OUTLINECOLOR 144 0 0
        END
END
END
Thanks for your help
Steve
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120629/edd265ab/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120629/edd265ab/attachment-0001.obj>
