[mapserver-users] [Mapserver-users] map cache - is it possible to access different was sources based on the current resolution or scale?
Mark Volz
MarkVolz at co.lyon.mn.us
Fri Jun 29 11:21:27 PDT 2012
Andreas,
Thank you for your reply. That seems like a good way to conserve disk space.
I have a couple concerns, First I don't know how to set up seemliness. Second, I am using windows (ms4w) so I don't know if that would have an impact on how or if I can set up seemliness. Did you set your seemliness up in the Linux OS, or under the Apache configuration?
Thanks
Mark Volz
GIS Specialist
-----Original Message-----
From: Eichner, Andreas - SID-NLKM [mailto:Andreas.Eichner at sid.sachsen.de]
Sent: Thursday, June 28, 2012 1:58 AM
To: Mark Volz; MapserverList OSGEO
Subject: AW: [mapserver-users] mapcache - is it possible to access different wms sources based on the current resolution or scale?
Hi Mark,
> The two layers are in the same grid. I didn't see any documentation
> on using symlink for zoom levels. How would I set that up in my
> configuration file?
you configure mapcache as usual and symlink the levels for the shared zoom levels. MapCache creates a directory structure in the filesystem for every tileset like <base>/<tileset>/<grid>/<zoom_level>.
You can also create it by hand (watch for correct access rights) and then symlink directories from the second tileset to the first. It should look something like this:
# cd <base>/<tileset1>/<grid>/; ls -ld
drwxrwxr-x 3 apache apache 3896 Aug 30 2011 00 drwxrwxr-x 3 apache apache 3896 Aug 30 2011 01 drwxrwxr-x 3 apache apache 3896 Aug 30 2011 02 drwxrwxr-x 3 apache apache 3896 Aug 30 2011 03 drwxrwxr-x 3 apache apache 3896 Aug 30 2011 04 drwxrwxr-x 3 apache apache 3896 Aug 30 2011 05 drwxrwxr-x 3 apache apache 3896 Aug 30 2011 06 drwxrwxr-x 3 apache apache 3896 Aug 30 2011 07 drwxrwxr-x 3 apache apache 3896 Aug 30 2011 08 drwxrwxr-x 3 apache apache 3896 Aug 30 2011 09 drwxrwxr-x 3 apache apache 3896 Aug 30 2011 10 drwxrwxr-x 3 apache apache 3896 Aug 30 2011 11 drwxrwxr-x 2 apache apache 3896 May 14 15:08 blanks
# cd <base>/<tileset2>/<grid>/; ls -ld
lrwxrwxrwx 1 root root 22 Dec 7 2011 05 -> ../../<tileset1>/05
lrwxrwxrwx 1 root root 22 Dec 7 2011 06 -> ../../<tileset1>/06
lrwxrwxrwx 1 root root 22 Dec 7 2011 07 -> ../../<tileset1>/07
lrwxrwxrwx 1 root root 22 Dec 7 2011 08 -> ../../<tileset1>/08
lrwxrwxrwx 1 root root 22 Dec 7 2011 09 -> ../../<tileset1>/09
lrwxrwxrwx 1 root root 22 Dec 7 2011 10 -> ../../<tileset1>/10
lrwxrwxrwx 1 root root 22 Dec 7 2011 11 -> ../../<tileset1>/11
lrwxrwxrwx 1 root root 22 Dec 7 2011 blanks ->
../../<tileset1>/blanks
drwxrwxr-x 2 apache apache 3896 May 14 15:08 <base>/<tileset1>/<grid>/blanks
This construct shares levels 5-11 between tileset1 and tileset2.
