[mapserver-users] MapServer 6.0.1 ignoring WMS options?
Armin Burger
armin.burger at gmx.net
Mon Mar 5 15:49:16 EST 2012
David
According to the WMS specs, BBOX parameters for getMap requests are
comma-separated, you are using spaces only (url-encoded as %20). I would
expect MS to return an exception instead of ignoring this.
armin
On 05/03/2012 21:20, David Miller wrote:
> Hi list!
> We have MapServer 6.0.1 installed on our Linux system (CentOS 5.7) and
> have encountered an issue where the WMS options (i.e. BBOX, HEIGHT,
> WIDTH) seem to be ignored for a GetMap request. I have checked options
> for and output from running the configure script for building the
> executable. The --with-proj and --with-wms options are specified
> (though one shouldn't need it if --with-proj is there correctly).
> Output from running the configure script indicates that the-DUSE_WMS_SVR
> compiler switch was on when compiling the mapwms.c code, which is where
> that becomes important. I examined that code and it's here that
> MapServer first uses the extents in the mapfile as defaults but then
> adjusts that based on the BBOX, HEIGHT, and WIDTH options in the GetMap
> request. Running -v on the resulting executable also indicates
> SUPPORTS=WMS_SERVER.
> The call to MapServer does produce an image but for the entire EXTENT of
> the data that's specified in the mapfile. Doesn't make any difference
> whether it's a raster or point layer.
> Example REQUEST:
> http://(our main site
> address)/cgi-bin/mapserv?REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&FORMAT=image%2Fpng&MODE=map&MAP=wxmap%2Fglmpvis.map&LAYERS=mosaic&SRS=EPSG%3A3857&TRANSPARENT=TRUE&STYLES=&BBOX=-13807095.590531%203308267.5857033%20-12241665.251469%204482340.3400001&WIDTH=640&HEIGHT=480
> First part of the mapfile:
> MAP
> NAME "testgrib"
> IMAGETYPE PNG
> EXTENT -14000000 3000000 -7000000 7000000
> As you can see, the EXTENT in the mapfile are different than the BBOX
> values. When I put the BBOX values in the EXTENT area in the mapfile,
> the image lines up with the map background as it should.
> So for some reason, it appears that something isn't being set correctly
> to allow our MapServer to accept standard WMS options. Perhaps somehow,
> this value of USE_WMS_SVR in mapwms.c isn't getting set correctly? But,
> by all the output we've checked, it looks like MapServer gets built
> correctly and to enable it as a WMS server.
> Anyone else with a similar issue or somewhere else we should check for a
> problem?
> Thanks for any help!
> Dave M
> mapserver-users at lists.osgeo.org
