[mapserver-users] Setup advice please?
Ben Madin
lists at remoteinformation.com.au
Tue Mar 6 01:41:14 EST 2012
G'day Brent,
On 03/03/2012, at 4:13 AM, mapserver-users-request at lists.osgeo.org wrote:
> Hopefully someone here can help.
> I have about 50Gb of high resolution aerial photos (geotiffs) to set up as a cached WMS service.
> We have a mapserver setup ready to use, with backups, etc. already sorted. The dataset is competely static.
> I'd like to set up MapProxy or Tilecache as a tiled WMS service for an OpenLayers front end, and possible other public use.
> I'm happy with a dynamically populated cache, rather than a pre-filled one, so the cache is built up as it is used.
> Can anyone experienced in this area suggest what sort of time is reasonable to expect a competent team to set this up in a professional way, with reasonable supporting docs, etc? Remembering we have a supported server to work with.
> It has been asked for by a small local environmental interest group with zero funds, and I need to get a reasonable commercial cost for such an exercise to start with.
We are happy with tilecache - probably several orders of magnitude improvement in speed, but more importantly was the reduced pressure on the cpu for tiled maps.
I suspect others are right - if you want to install tile cache, '''and you know what you are doing''', 35 minutes is about right (I did it yesterday on my laptop with the current .tar.gz for a workshop)
If you want a quick summary of the steps to do this, I suspect another hour should be adequate.
But, if you want a bomb-proof explanation of how to re-install it with troubleshooting guide, maybe three days is reasonable - my experience is that working guides that we are happy with internally are often not acceptable to external organisations, so you can probably specify that you are happy for the dot point form.
I would however quote three days for MapProxy, because I have no experience with it…
cheers
Ben
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120306/df5bbee0/attachment.html
