[mapserver-users] draw line using mysql sahpe file
Murat Beyhan
beyhan at deprem.gov.tr
Wed Mar 7 02:45:21 EST 2012
Dear All,
For 2 weeks I struggled to draw simple line using mysql database in
order to collect to many lines and draw only desired one on the map I
followed many way but could not solve the problem
at the beginning of my work I stored start and end of the line point on
the database as a table on mysql then I try to draw it using ogr. but I
could not draw it.
Then I firs create shape file of lines than I store it on mysql spatial
database by following
ogr2ogr -f MySQL MySQL:testogr,user=root,password=password123
sfault1.shp -nln sfault -append -overwrite -lco GEOMETRY_NAME=SHAPE2
then structure of the table created by this command as follows:
OGR_FID
int(11)
Yes
NULL
SHAPE2
geometry
Yes
NULL
id
decimal(1,0)
Yes
NULL
lon
double(8,4)
Yes
NULL
lat
double(7,4)
Yes
NULL
eq_id
varchar(14)
Yes
NULL
same database testogr has a two another table which collect
geometry_column and spatial_ref_sys.
then I try to draw it on mapserver
then I succeeded but it draws all of the line stored in this table using
following map layer.
LAYER
NAME "fault"
TYPE line
STATUS default
CONNECTIONTYPE OGR
CONNECTION '<OGRVRTDataSource>
<OGRVRTLayer name="sfault">
<SrcDataSource>MYSQL:testogr,user=root,password=password123,host=localhost,port=3306,tables=sfault</SrcDataSource>
</OGRVRTLayer>
</OGRVRTDataSource>'
DATA sfault
CLASS
NAME "Kaynak Fay/Source Fault"
SYMBOL "cline"
SIZE 3
COLOR 255 0 0
END
END
But I desire only one of them using eq_id column but when I make sql
statement as follows. I mean when I add sql statement it draws nothing.
But be sure same eq_id comes to map file correctly to draw point of
epicenter. There is no problem for it. Also I use EXPRESSION FOR CLASS
also it doesn't draw line on the map. Previous map draws all, following
draws nothing. How can I pass this handicap. Please let help me.
LAYER
NAME "fault"
TYPE line
STATUS default
CONNECTIONTYPE OGR
<SrcSQL>SELECT eq_id from sfault where eq_id like "%eq_id%" </SrcSQL>
</OGRVRTLayer>
DATA sfault
# CLASSITEM "eq_id"
CLASS
# EXPRESSION ([eq_id] EQ 'eq_id') !!!!!! this also doesn't work
SYMBOL "cline"
SIZE 3
COLOR 255 0 0
END
END
Murat BEYHAN
Geophysical Engineer, M.Sc.
Prime Ministry
Disaster and Emergency Management Presidency
Earthquake Department
Address: Eskisehir Yolu 12. Km.
Lodumlu/ANKARA
Tel: 312 2872680-1556
email:beyhan at deprem.gov.tr
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
