[mapserver-users] Getting an image scaled to pixels
Stuart
reachstuart at yahoo.com.au
Thu Mar 8 19:32:52 EST 2012
I have a csharp application using map_script that I am using to cut up
an ECW file into tiles for display on a Bing map. The issue I am
having is that each tile slightly overlaps others above and below it.
The procedure I am using is as follows:
I load the basic map file below add the projection and units from
within a csharp application:
mapserverMap = new mapObj(mapOutputPath + mapFileName);
mapserverMap.setWKTProjection("+proj=merc +a=6378137 +b=6378137
+lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null
+no_defs ");
mapserverMap.setSize(256, 256);
mapserverMap.units = MS_UNITS.MS_DD ;
I then use the csharp application to add a single RASTER layer
layerObj layer = new layerObj(mapserverMap);
Console.WriteLine(mapserverMap.layerorder);
layer.name = ecwName;
layer.type = MS_LAYER_TYPE.MS_LAYER_RASTER;
layer.status = mapscript.MS_ON;
layer.sizeunits = (int)MS_UNITS.MS_PIXELS;
var extentdoubles = GetPlanExtentFromDB(ecwName, planConnectionString);
layer.setExtent(extentdoubles[0], extentdoubles[1],
extentdoubles[2], extentdoubles[3]);
layer.data = mapOutputPath + ecwName + ".ecw";
I have identified the issue is when for each quadKey I set the
mapserverMap extent to the bounding box of the quadKey MapServer
changes the latitudes of its extent to fit the map size (256 x 256)
e.g. for quadKey 31121320312020 i set the MapServer extent to:
maxX
152.95166015625
maxY
-30.334953881988554
minX
152.9296875
minY
-30.353916372297036
Then after setting the extent if I ask MapServer for its extent it returns:
mapserverMap.extent
{OSGeo.MapServer.rectObj}
maxx: 152.95166015625
maxy: -30.333448799017795
minx: 152.9296875
miny: -30.355421455267795
Notice the Longitudes are the same but the Latitudes (minY, maxY) have
been stretched.
So my question is that when I set mapserverMap object to the bounding
box I want it to be set to the latitude and longitude given and
stretched to fit the map size (256 x 256) rather than MapServer
modifying the latitudes to fit the map size.
Any help would be appreciated.
Stuart
Here is the starting map file
MAP
NAME MyMap
DEBUG ON
IMAGECOLOR 128 155 155
UNITS DD
RESOLUTION 96
TRANSPARENT OFF
CONFIG "PROJ_LIB" "/ms4w/proj/nad/"
CONFIG "CPL_DEBUG" "ON"
SYMBOLSET ./etc/symbols.sym
IMAGETYPE png
FONTSET ./etc/fonts.txt
END
