[mapserver-users] File Map & SLD rendering
Stephen Woodbridge woodbri at swoodbridge.com
Sat Mar 10 10:38:26 EST 2012
On 3/10/2012 2:58 AM, Andrea Peri wrote:
> Hi,
> I like to use the SLD to describe the rendering of a WMS service.
> I understand the SLD is usable as a querystring parameter from a remote
> call, but
> I like instead to use it as a server side configuration setting.
> Is this possible ?
Not that I am aware of. Currently mapserver uses its mapfile for
defining the layers and styles. There is also an XML mapfile utility
that will allow you to define the mapfile in XML and then convert it to
the standard mapfile so mapserver can read it.
-Steve W
