[mapserver-users] WMSGetFeatureInfo problem
Karina Guardado
kguardado at gmail.com
Mon Mar 12 16:38:50 EDT 2012
Hi Paolo,
Thank you very much for your help, Now it is working and I think now I
understand how do the Template work after looking at some examples and
creating 35 files even more. Here I mention some of the steps I follow so
maybe those can be helpfull for other people who probably have no idea
where to begin.
1. Download the last Openlayers version and copy into my folder and add a
link to the Openlayers.js
<script type="text/javascript"
src="OpenLayers-2.11/lib/Firebug/firebug.js"></script>
src="OpenLayers-2.11/lib/OpenLayers.js"></script>
2. I added the following code to my application in order to add the
WMSGetFeatureInfo Control
toolbar.addControl(new OpenLayers.Control.WMSGetFeatureInfo({
url: '
http://mydomain/cgi-bin/mapserv?MAP=/var/www/myaddress/mymapfile.map&',
title: 'Identify features by clicking',
queryVisible: true,
infoFormat:'text/html',
click: 'true',
layers: [DepartamentosSRMSS, Municipios,
LimiteDepartamental],
eventListeners: {
getfeatureinfo: function(event) {
map.addPopup(new OpenLayers.Popup.FramedCloud(
"chicken",
map.getLonLatFromPixel(event.xy),
null,
event.text,
null,
true
isDefault: true,
title: 'Info'
iconCls: 'query',
toggleGroup: 'map'
3. I Created the layers like the one below
LAYER
NAME 'Municipios'
TYPE polygon
DUMP true
EXTENT 254093.5384 43485.4771 723948.4474 385070.6867
CONNECTIONTYPE postgis
CONNECTION "dbname='mydb' host=localhost port=5432 user='myuser'
password='mypassword' sslmode=disable"
DATA 'the_geom FROM "SRMSSmunici" using unique gid using SRID=-1'
HEADER "templates/header.html"
TEMPLATE "templates/content.html"
FOOTER "templates/footer.html"
METADATA
'ows_title' 'SRMSSmunici'
"wms_srs" "epsg:8913 epsg:4326"
'ows_geometries' 'the_geom'
'wms_enable_request' '*'
'wms_include_items' 'all'
'ows_mygeom_type' 'polygon'
"wms_feature_info_mime_type" "text/html"
'queryable' 'true'
"wms_enable_request" "GetMap GetFeatureInfo"
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
"init=epsg:8913"
END
CLASS
NAME 'SRMSSmunici'
STYLE
WIDTH 2.4
OUTLINECOLOR 115 0 0
END
END
END
4.Create the Template files
Header.html
<!-- MapServer Template -->
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "
http://www.w3.org/TR/html4/transitional.dtd">
<html>
<head>
<!-- enforce the client to display result html as UTF-8 encoding -->
<meta http-equiv="content-type" content="text/html;
charset=UTF-8"></meta>
<title>GetFeatureInfo Response</title>
</head>
<body>
<table>
Content.html
<caption>Layer: Arqueológico</caption>
<tbody>
<th >Nombre</th>
<th >Sitio</th>
<th >Id</th>
<tr >
<td >[item name="Nombre" format=$value escape=none]</td>
<td >[item name="Sitio" format=$value escape=none]</td>
<td >[item name="Id" format=$value escape=none]</td>
</tr>
Footer.html
</tbody>
</table>
<br/>
</body>
</html>
On Thu, Mar 8, 2012 at 10:27 AM, Paolo Corti <pcorti at gmail.com> wrote:
> > But when i click on one point for example it is looking but doesn't shoe
> > anything and when looking at the fireburg result I found this
> > msWMSFeatureInfo(): WMS server error. Unsupported INFO_FORMAT value
> > (text/html).
> > I ask me if this is a problem with mapserver or with openlayers, any help
> > please.
> most likely you are missing the the wms_feature_info_mime_type
> metadata item [1]:
> add "wms_feature_info_mime_type" "text/html" in the WEB/METADATA
> section of mapfile
> best regards
> P
> [1] http://mapserver.org/ogc/wms_server.html
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
Best regards,
Karina Guardado
Geoinformatic
El Salvador
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120312/7cb8e0c2/attachment.html
