[mapserver-users] How accessing Postgis Raster with MapServer
Paolo Corti pcorti at gmail.com
Tue Mar 13 18:38:43 EDT 2012
On Tue, Mar 13, 2012 at 10:34 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
> Hi,
> I'm try-ing to access a postgis raster using mapserver trunk,
> but it don't seem work.
> I don't understand if the problem is on the postgis raster or in the mapfile
> settings.
> So I like to know if this mapfile setting is ok to call a postgis raster
> I use this mapfile settings:
> The table ofc10k_single_2010 has only 1 raster loaded with this call:
> raster2pgsql -s 3003 -l 3 -C -e -Y -I -M 216100_2010.tif -F -f rast -d -t
> 100x100 my_schema.ofc10k_single_2010 > ofc10k_single_2010.sql
> The gdal available is gdal 1.9.0.
> The mapfile layer section is this:
>   LAYER
>     NAME "ofc10k_single"
>     STATUS ON
>     EXTENT 1559445 4921905 1566395 4927805
>     TYPE raster
>     CONNECTIONTYPE ogr
>     DATA "PG:host='localhost' port='5432' dbname='my_database'
> user='postgres' password='my_password' schema='my_schema'
> table='ofc10k_single_2010' mode='2'"
>     PROCESSING "NODATA=0"
>     PROCESSING "SCALE=-100.5,100.5"
>     PROCESSING "SCALE_BUCKETS=201"
>     # ... other standard raster processing functions here
>     PROJECTION
>       "init=epsg:3003"
>     END
>     METADATA
>       "wms_title" "OFC 1:10.000 single"
>       "wms_srs" "EPSG:3003 EPSG:4326"
>     END
>     OFFSITE 255 255 255
>     OPACITY 100
>   END
> Thx for any hint.
Hi Andrea
for sure you have to remove the line with the CONNECTIONTYPE set to
ogr (that is only for vectorial layers [0]).
The rest looks fine to me, but I cannot test it right now.
BTW, have you read this [1] faq?
ciao
P
[0] http://www.mapserver.org/input/vector/ogr.html
[1] http://www.postgis.org/documentation/manual-svn/RT_FAQ.html#id3059359
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
