[mapserver-users] PHP Startup: MapScript: Unable to initialize
module
Lester Caine
lester at lsces.co.uk
Thu Mar 15 15:58:04 EDT 2012
Steve.Toutant at inspq.qc.ca wrote:
> I have a warning with php and it seems to be related with the module Mapscript.
> With apache my php file is well executed , from a command line it is also well
> executed by I get this warning:
> PHP Warning: PHP Startup: MapScript: Unable to initialize module
> Module compiled with module API=20060613
> PHP compiled with module API=20090626
> These options need to match
> My php script content has nothing related to mapserv or mapscript though...
> phpinfo() doesn't return anything about MapScript, I guess it should?
> But What can I do about that?
Steve ... this is a common problem with PHP. Your main installation has been
upgraded to 5.3.8 but Mapscript was installed from another source and so is
still 'stamped' with the previous version number which must be some time
previously since its 2006 ;)
Fixing the problem just involves either getting a pre-compiled copy of mapscript
for php5.3.8 or you may need to compile it yourself since SLES11 is obviously
not managing the version control properly. My own SUSE12.1 setup is pulling the
correct versions of the files.
Lester Caine - G8HFL
Contact - http://lsces.co.uk/wiki/?page=contact
L.S.Caine Electronic Services - http://lsces.co.uk
EnquirySolve - http://enquirysolve.com/
Model Engineers Digital Workshop - http://medw.co.uk//
Firebird - http://www.firebirdsql.org/index.php
