[mapserver-users] Re: Run-time Substitution and Raster file
problem
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Sat Mar 17 09:03:06 EDT 2012
Start from something simple and try to use DAT with tiff file with %file% and make it to work first. I am pretty sure that is will work. Perhaps there is some trouble with validation or something. If you do not have a luck with RASTER make a similar vector layer and see if you can change %file% with a variable then.
Here are snippets from working vector data examples
DATA "way from (select (way),osm_id,tags from osm_polygon where (tags @>'%tag%=>%value%')) as foo using unique osm_id using srid=3067"
VALIDATION
tag "."
value "."
END
With this setting user must give both tag and value parameters as &tag=something&value=else. Defaults can be given as
"default_tag" "amenity"
"default_value" "toilets"
-Jukka Rahkonen-
________________________________________
teknocreator wrote:
> Thomas,
> I'm not positive about what you wrote as I don't enclose the data string
with '*'. The '*' in the "*_validation_pattern" I mentioned was just a
wildcard for the RTS variables that I use as we use a few in the DB call I
mentioned.
However, when I tried what you suggested, the parser tries to find a file
named ds_vis%fhour%.grb:
msDrawMap(): Image handling error. Failed to draw layer named 'mosaic'.
msDrawRasterLayerLow(): Unable to access file. Corrupt, empty or missing
file '../grib/%file%' for layer 'mosaic'.
I've tried variations on this using the full path enclosed in quotes (which
throws the error above) and without (which throws the first one). Then
tried this:
DATA ../grib/%file%, (full path)/grib/%file% (with and without quotes),
thinking I should pass the whole file name.
I either get a parsing error for the '%' or it can't find the file because
the quotes cause the parser to look for a filename with '%' in it.
Dave M
View this message in context: http://osgeo-org.1560.n6.nabble.com/Run-time-Substitution-and-Raster-file-problem-tp4626749p4627796.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
