[mapserver-users] mapserver displaying only the background image as
specified in the
IMAGECOLOR field in the mapfile. No image generated from the shapefile data.
Annu Anurag
i.skidoosh at gmail.com
Mon Mar 19 15:54:41 EDT 2012
I've used mapserver before. Although it was an older version. I was just
trying to set it up again on my computer. I ran the hello_world example
from Bill Kropla's book. It worked fine. But when I'm trying to run the
first.map, there are no errors in the logs. I checked both mapserver error
log and the lighttpd error log. But the image displayed only comprises of
the background color specified in the mapfile. No actual image is generated
from the shapefile data provided. There are no errors either logged so I
can't debug. Its been 5 days now. I have tried many methods to debug but I
have failed always. Attached is mapfile and the corresponding html file.
please help.
Mapfile:
MAP
NAME "First"
CONFIG "MS_ERRORFILE" "/var/www/tmp/ms_error.txt"
CONFIG "PROJ_DEBUG" "ON"
CONFIG "CPL_DEBUG" "ON"
SIZE 1024 768
IMAGECOLOR 111 111 111
IMAGETYPE jpeg
SHAPEPATH /var/www/Delhi/
EXTENT 76.898503 28.410443 77.337521 28.862691
WEB
TEMPLATE '/var/www/first.html'
IMAGEPATH '/var/www/tmp/'
IMAGEURL '/tmp/'
END
LAYER
NAME "Highways"
DEBUG 5
STATUS ON
TYPE LINE
DATA asia_southern_asia_india_delhi_highway
LABELITEM "NAME"
CLASS
STYLE
OUTLINECOLOR 123 0 0
COLOR 0 255 0
END
LABEL
COLOR 255 0 0
SIZE SMALL
END
END
END
END
END
Template and initialization html file:
<!-- Mapserver Template -->
<html>
<head><title>MapServer First Map</title></head>
<body>
<form method=POST action="/mapserv">
<input type="submit" value="Click Me">
<input type="hidden" name="map" value="/var/www/mapfiles/first.map">
<input type="hidden" name="map_web_imagepath" value="">
</form>
<IMG SRC="[img]" width=1024 height=768 border=10>
</body>
</html>
The paths seem to be fine as I'm using the same paths I used while running
hello_world and it ran fine. Please help.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120320/a5ae6cdd/attachment.html
