[mapserver-users] Charset encoding for Labels [SOLVED]
Fernando Norte
fernando at globalgeo.com.br
Thu Mar 22 09:59:08 EDT 2012
SOLVED
I solved, kind by accident, styling the fonts.
I'd set the TYPE truetype and use a FONTSET with Arial.ttf and the problem
is solved. The BitMap type default maybe use a standard font that doesn't
had the 'special' characteres.
2012/3/22 Fernando Norte <fernando at globalgeo.com.br>
> Hello,
> I'm trying to solve a problem with character encoding with MapServer. I
> have points instead of the accent character at the LABELs.
> I'd changed the shapefile dbf from ISO8859-1 to UTF-8, try to use encoding
> at the mapfile in both versions, but sometimes the result is worse.
> There is some solution for this?
> Thanks in advance,
> Fernando G Norte
> Nova Lima / MG - Brazil
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120322/467033e8/attachment-0001.html
