[mapserver-users] Label priorities in MapServer 6
Christy Nieman
cnieman at dmsolutions.ca
Thu Mar 22 11:34:53 EDT 2012
Ah. This seems to be a difference between using ANNOTATIONS vs.
POINTS. I was trying to get the same result as using an ANNOTATION to
draw a point marker with a label in a POINT layer (i.e. that the point
only gets drawn if the label does).
Never mind :)
C
On 03/22/2012 11:16 AM, Christy Nieman wrote:
> Hi,
> I was hoping someone could confirm the following for me:
> In MapServer 5.6, labelling seems to still honour the last in-first
> out idea, in addition to priorities. I.e. when two layers have the
> same label priority, the one that appears closest to the end of the
> mapfile will "take priority" over the one that appeared earlier in the
> mapfile.
> In MapServer 6, it seems that of these two layers with the same
> priority, the layer that appears first in the mapfile will "take
> priority" over the layer that appears later.
> Is this correct, or am I missing something?
> Thanks,
> Christy
