[mapserver-users] ./mapserv: error loading shared libraries:
Alberto Najera anajera at bicimapas.com.mx
Thu Mar 22 13:13:47 EDT 2012
I am installing Mapserver in a Centos 5 distribution. All the installation
process seems to be done correctly, but after running  "make"  in Mapserver
and testing with ./mapserv we are getting this error message:
./mapserv: error loading shared libraries: libjpeg.so.8: cannot open shared
object file: no such file or directory
We have installed jpeg-8d to the default directories /usr/local/lib/ using
the ./configure --disable-static  to make sure all the libraries are shared.
Also, we are using gdal-1.9.0 and it is configured to use the external
jpeg-8d library.
I cannot understand why we are getting this error message. Furthermore, I
really do not need to use JPEG as I plan to use PNG images for rendering our
vector data.  I have attempted to configure Mapserver without JPEG by
several means including not calling for it, using   without-jpeg  and
--disable-jpeg  and nevertheless, configure always shows that JPEG support
will be used.
Can you provide some help on how to fix this?  I have been dealing with this
issue for over 10 days and cannot find a solution
Alberto Najera
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120322/764edf4f/attachment-0001.html
