[mapserver-users] ./mapserv: error loading shared libraries:
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Mar 22 14:06:59 EDT 2012
First thing run:
sudo ldconfig
and see if that fixes things.
What does this report:
ls -l /usr/lib/libjpeg*
-SteveW
On 3/22/2012 1:13 PM, Alberto Najera wrote:
> I am installing Mapserver in a Centos 5 distribution. All the
> installation process seems to be done correctly, but after
> running“make”in Mapserver and testing with ./mapserv we are getting this
> error message:
> ./mapserv: error loading shared libraries: libjpeg.so.8: cannot open
> shared object file: no such file or directory
> We have installed jpeg-8d to the default directories /usr/local/lib/
> using the ./configure --disable-staticto make sure all the libraries are
> shared.
> Also, we are using gdal-1.9.0 and it is configured to use the external
> jpeg-8d library.
> I cannot understand why we are getting this error message. Furthermore,
> I really do not need to use JPEG as I plan to use PNG images for
> rendering our vector data.I have attempted to configure Mapserver
> without JPEG by several means including not calling for it,
> usingwithout-jpegand--disable-jpegand nevertheless, configure always
> shows that JPEG support will be used.
> Can you provide some help on how to fix this?I have been dealing with
> this issue for over 10 days and cannot find a solution
> Alberto Najera
> mapserver-users at lists.osgeo.org
