[mapserver-users] Re: tinyows - installation problem
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu Mar 29 00:16:13 EDT 2012
Error seems to say that TinyOWS finds the database but not PostGIS functions from it. What do you get by this SQL query from your database
select postgis_version()
-Jukka Rahkonen-
Neelima Emmani wrote:
> Hi all,
> I am trying to install tinyows in my ms4w package. First of all, I am new to this tinyows.
> Process followed :
> Took files from tinyows folder and kept them in their related paths like
* tinyows.exe under apache>cgi-bin
* tinyows folder under ms4w>apps
* httpd_tinyows under ms4w>httpd.d and also set the tinyows environment in ms4w/Apache/conf/httpd.conf using statements from httpd_tinyows
* configuration - To configure made changes in the config.xml which is under tinyows folder. There i have my dbname , username, password and layername as follows -
<tinyows online_resource="http://127.0.0.1/cgi-bin/tinyows.exe"
schema_dir="C:/ms4w/apps/tinyows/schema/"
check_schema="0"
log="C:/ms4w/tmp/ms_tmp/tows.log"
log_level="1">
<pg host="localhost" user="postgres" password="admin" dbname="postgis" port="5432"/>
<metadata name="TinyOWS Server"
title="TinyOWS Server - Demo Service" />
<contact name="TinyOWS Server"
site="http://www.tinyows.org/"
email="tinyows-users at lists.maptools.org" />
<layer retrievable="1"
writable="0"
ns_prefix="tows"
ns_uri="http://127.0.0.1/"
prefix="tows"
server="http://127.0.0.1/"
schema="public"
name="maps"
title="maps" />
</tinyows>
* And then i opened cmd, went to the cgi-bin path and said tinyows --check. Then an exception is thrown as follows --
<?xml version='1.0' encoding='UTF-8'?>
<ows:ExceptionReport
xmlns='http://www.opengis.net/ows'
xmlns:ows='http://www.opengis.net/ows'
xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'
xsi:schemaLocation='http://www.opengis.net/ows http://schemas.opengis.net/ows/1
.0.0/owsExceptionReport.xsd'
version='1.1.0' language='en'>
<ows:Exception exceptionCode='ConnectionFailed' locator='init_OWS'>
<ows:ExceptionText>No PostGIS available in database</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
Can anyone suggest where is the problem. Usernmae, password, dbname and hostname are correct . there is no mistake in that. Do i need top do any further settings. Please suugest me , if any idea.
Awaiting reply.
With Regards,
Neelima Emmani
