[mapserver-users] polygon border artifacts
thomas bonfort
thomas.bonfort at gmail.com
Fri May 4 06:49:11 EDT 2012
with a recentish version of mapserver, try setting
PROCESSING "APPROXIMATION_SCALE=FULL"
on your ocean layer, to avoid feature simplification (it will slow
down the rendering if the resolution of your data is much greater than
the resolution of the requested map).
thomas
On Fri, May 4, 2012 at 12:16 PM, Sven Geggus
<lists at fuchsschwanzdomain.de> wrote:
> Hello,
> the brilliant osm coastline tool from Jochen Topf
> (http://blog.jochentopf.com/2012-04-19-more-coastlines-stuff.html)
> enables for creating nice ocean or landcover polygons from
> Openstreetmap data. Well, this is where my mapserver problem
> starts...
> For illustration of the problem I just created ocean polygons around
> canary islands
> http://home.geggus.net/pub/ocean-canary-islands.zip
> They are in sperical mercator using a huge overlap of 30meters to
> avoid artifacts.
> However artifacts (which seem to depend on scale) still arise:
> http://home.geggus.net/pub/ocean.png
> Here is the mapfile and shp2img command I used for rendering:
> shp2img -o ocean.png -m ocean.map -e -1917656.09 3248262.91 -1839384.59 3326534.41 -s 512 512
> MAP
> OUTPUTFORMAT
> NAME agg
> DRIVER AGG/PNG8
> FORMATOPTION "INTERLACE=OFF"
> MIMETYPE "image/png"
> END
> EXTENT -180 -85 180 85
> IMAGECOLOR 255 0 0
> WEB
> METADATA
> "ows_enable_request" "*"
> wms_srs "EPSG:4326 EPSG:3857"
> END
> END
> PROJECTION
> "init=epsg:3857"
> END
> LAYER
> PROCESSING "CLOSE_CONNECTION=DEFER"
> NAME "ocean"
> TYPE POLYGON
> STATUS ON
> DATA "ocean-canary-islands"
> PROJECTION
> "init=epsg:3857"
> END
> CLASS
> STYLE
> COLOR 128 255 255
> END
> END # of class
> END # of layer
> END
> The only workaround I found so far is to use an outline:
> OUTLINECOLOR 128 255 255
> WIDTH 1
> Is this a bug in mapserver or is there something else which I can do?
> Sven
> "Ich fürchte mich nicht vor der Rückkehr der Faschisten in der Maske der
> Faschisten, sondern vor der Rückkehr der Faschisten in der Maske der
> Demokraten" (Theodor W. Adorno)
> /me is giggls at ircnet, http://sven.gegg.us/ on the Web
> mapserver-users at lists.osgeo.org
