[mapserver-users] Mapserver layer over Google Maps
Alberto Najera
anajera at bicimapas.com.mx
Sun May 6 21:33:26 EDT 2012
Hello list,
Using OpenLayers, I am trying to draw a Mapserver WMS layer on top of Google
Maps. I am aware of the Spherical Mercator projection and I am trying to use
the alias projection method described at the end of this link
http://docs.openlayers.org/library/spherical_mercator
The mapserver layer is in Lat/Lon WGS84 (EPSG:4326)
I have made some progress so far and I can see the label of the object at
full zoom, but as I zoom in it does not show anymore and the feature does
not show either.
Any help in finding the issue would be greatly appreciated.
This is the relevant map file code:
MAP
WEB
TEMPLATE "/home/bicimapas/www/bcmpms.html"
IMAGEPATH "/home/bicimapas/www/images/"
IMAGEURL "/images/"
METADATA
"wms_title" "BiciMapasMS"
"wms_onlineresource"
"http://my_host/cgi-bin/mapserv?map=/home/bicimapas/mapdata/BiciMapasMS_Metr
o.map&"
"wms_srs" "EPSG:4326 EPSG:3857"
"wms_enable_request" "*"
END
END
PROJECTION
"init=epsg:4326"
END
LAYER
NAME "fibraoptica"
DATA "fibraoptica"
STATUS on
TYPE line
LABELCACHE on
LABELITEM "RASGO"
CLASSITEM "RASGO"
METADATA
"wms_title" "fibraoptica"
"wms_srs" "EPSG:4326"
"wms_include_items" "all"
END
CLASS
NAME "fibraoptica"
EXPRESSION "fibra"
#MAXSCALEDENOM 15000
STYLE
WIDTH 4
COLOR 0 0 0
END
STYLE
WIDTH 2
COLOR 255 0 0
END
LABEL
TYPE truetype
FONT "Arial"
ANTIALIAS true
SIZE 7
OUTLINECOLOR 255 255 255
COLOR 0 0 0
POSITION cc
ANGLE follow
END # label trutype
END # class fibraoptica
END # layer fibraoptica
END # mapfile
And the OpenLayers code is:
<html lang='en'>
<head>
<meta charset='utf-8' />
<script type='text/javascript' src='OpenLayers.js'></script>
<script
src="http://maps.google.com/maps/api/js?sensor=false"></script>
<script type='text/javascript'>
var map;
function init() {
// Setup map object
map = new OpenLayers.Map('map_element', {});
// Add Google Maps Layer
var google_map_layer = new OpenLayers.Layer.Google(
'Google Map Layer',
{"sphericalMercator": true}
// override default epsg code
aliasproj = new OpenLayers.Projection("EPSG:3857");
google_map_layer.projection = aliasproj;
// Add the Google Maps layer
map.addLayer(google_map_layer);
//add the mapserver layer
var layer3 = new OpenLayers.Layer.WMS(
"Fibra Optica",
"http://my_host/cgi-bin/mapserv?",
{map: '/home/bicimapas/mapdata/BiciMapasMS_Metro.map',
layers:'fibraoptica', transparent: true},
{isBaseLayer:false});
// Add the layer
map.addLayer(layer3);
// Add a layer switcher control
map.addControl(new OpenLayers.Control.LayerSwitcher({}));
//Zoom the map to the max extent
if(!map.getCenter()){
map.zoomToMaxExtent();
</script>
</head>
Thanks in advance
Alberto Najera
