[mapserver-users] Truetype font rendering changes?
Johan Forsman
Johan.Forsman at LA.GOV
Mon May 7 11:31:30 EDT 2012
No. Unfortunately none of the sites are accessible from the outside. The best I can do are screenshots.
I attached two examples from the same Linux server. One is from the FGS95 (MS54) environment and the other (MS60) is under the "main" system environment. Both samples are of Arial Narrow 7 point, and the image is rendered using the following output format:
OUTPUTFORMAT
NAME 'agg_q'
DRIVER AGG/PNG
IMAGEMODE RGB
FORMATOPTION "QUANTIZE_FORCE=ON"
FORMATOPTION "QUANTIZE_DITHER=OFF"
FORMATOPTION "QUANTIZE_COLORS=256"
END
I freely confess to not knowing much about the various output formats. This one I picked from the list some time long ago. I tried other formats also, both 8- and 24-bit and both the AGG and Cairo drivers, but I have not noticed any clear differences.
Thanks for any suggestions and I'll be glad to collect additional information if needed.
Johan.
-----Original Message-----
From: Lime, Steve D (DNR) [mailto:Steve.Lime at state.mn.us]
Sent: Monday, May 07, 2012 9:43 AM
To: Johan Forsman; Donald Kerr; mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] Truetype font rendering changes?
Is that test case available someplace?
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Johan Forsman
Sent: Monday, May 07, 2012 8:32 AM
To: Donald Kerr; mapserver-users at lists.osgeo.org
Thank you for the suggestion however I regret to report that there is no discernible difference in the appearance of the text when using cairopng in the Windows environment. I have also created a test case using MS6 on the same Linux server (but outside the FGS95 environment) as my MS5.4 and the text is rendered exactly the same as on the Windows platform, with the same reduced legibility.
Thanks,
Johan.
From: Donald Kerr [mailto:donald.kerr at dkerr.co.uk]
Sent: Thursday, May 03, 2012 12:39 PM
To: Johan Forsman; mapserver-users at lists.osgeo.org
Johan,
Have you tried "cairopng" as an alternative to AGG?
Regards,
Donald
Sent: 03 May 2012 16:07
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Truetype font rendering changes?
Hello All:
I am in the process of migrating from MapServer 5.4 (FGS95 on Linux) to MapServer 6 (MS4W3 on Windows Server 2008 R2). Most things are migrating well however I have a peculiar TrueType font rendering issue where the readability on the new system is far less than on the old system. I have attached two screenshots taken at the same scale to illustrate the issue. In these images the parish labels are Arial Bold Italic 6 pt., the interstate shields are Arial 8 pt., and US highway shields are Arial Narrow 7 pt. The TTF files and the MAP files were copied directly from the old system to the new system. I have tried with antialias on and off in the label definition and with a couple of different AGG image output formats but there are no visible differences.
I would really appreciate any suggestions or pointers where to investigate.
Thanks!
Johan Forsman
Geologist
Engineering Services
LDHH-OPH-CEHS
225.342.7309
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Type: image/png
Desc: ms60_linux2.PNG
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120507/24b078f0/ms60_linux2-0001.png
Type: image/png
Desc: ms54_linux2.PNG
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120507/24b078f0/ms54_linux2-0001.png
