[mapserver-users] multiple transparent colours
Stephen Woodbridge
woodbri at swoodbridge.com
Wed May 9 09:44:43 EDT 2012
Frank,
Would it be possible to make mapserver pick up the NODATA value from the
gdal source file. Maybe using a keyword like "OFFSITE AUTO". This would
be especially useful when using a tileindex.
Any thoughts on this? Should I create a ticket for something like this?
-Steve W
On 5/9/2012 9:36 AM, Rahkonen Jukka wrote:
> Hi,
> Perhaps you cannot literally set a colour as transparent in a tiff but
> for sure you can define a nodata value and then applications can make
> nodata pixels transparent. That is the most normal way to do it with
> Mapserver and OFFSITE. I believe that Mapserver does not even care if
> tiff has a nodata tag set but you can give whatever value for offsite in
> a mapfile.
> I have not played at all with alpha, but perhaps there is some way to
> give a list of pixel values which should be transparent and convert them
> all to a suitable alpha channel value.
> -Jukka Rahkonen-
> Fernando Nortewrote:
> Hi Christoph,
> I try to understand, how did you set the specific color to
> transparent in a TIFF?
> For raster you can set the level of transparency/opacity to the
> image not to a color.
> Att,
> *Fernando Norte*
> Desenvolvedor SIGWeb
> tel.(31) 2533.9900
> cel.(31) 9119.8814
> skype: fernandoglobalgeo
> Endereço: Alameda do Ingá, 88, 6º andar, Vale do Sereno
> Nova Lima/MG - CEP: 34.000-000
> www.globalgeo.com.br <http://www.globalgeo.com.br/>
> "O presente documento pode conter material confidencial ou seu
> sigilo é protegido por lei.
> Quaisquer informações nele contida são destinadas exclusivamente
> ao(s) seu(s) destinatário(s)
> não devendo em nenhuma hipótese ser repassado a terceiros".
> 2012/5/9 Christoph Schumacher
> <christoph.schumacher at pbs-schumacher.de
> <mailto:christoph.schumacher at pbs-schumacher.de>>
> Hello everybody,
> I have a problem setting up my wms.
> I have multiple tiff images that have different colours to be
> set up as transparaent.
> With the offsite parameter I can only set one colour transparent.
> Now my question is: Is there a way to make various colour
> transparent??
> best wishes and thank you very much
> christoph
> mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
