[mapserver-users] Help Required with WMS Time
Helen San Segundo Navazo
hsansegundo at meteo.cat
Thu May 10 07:48:39 EDT 2012
I don't use the time dimension, what I use is run-time substitution
http://mapserver.org/cgi/runsub.html
I have 6 variables. You have to put the validation pattern inside the
metadata tag and a validation tag with the pattern of your variables.
With this you can invoke the params in the url. If you put them the
query will be with the values in the url, if not, then the query will be
with the default values defined in the metadata tag.
Hope this help you,
Helen
LAYER
NAME 'name'
HEADER "templates/getfeatureinfo_header.html" # header html template
TEMPLATE "templates/getfeatureinfo_content.html" # content html
template
FOOTER "templates/getfeatureinfo_footer.html" # footer html template
METADATA
'ows_title' 'title'
'wms_feature_info_mime_type' "text/html"
"gml_include_items" "all"
"wms_include_items" "all"
'aini_validation_pattern' '^[0-9]{1,8}$'
'afi_validation_pattern' '^[0-9]{1,8}$'
'mini_validation_pattern' '^[0-9]{1,8}$'
'mfi_validation_pattern' '^[0-9]{1,8}$'
'dini_validation_pattern' '^[0-9]{1,8}$'
'dfi_validation_pattern' '^[0-9]{1,8}$'
'default_aini' '2012'
'default_afi' '2012'
'default_mini' '4'
'default_mfi' '4'
'default_dini' '24'
'default_dfi' '25'
END
VALIDATION
'aini' '^[0-9]{1,8}$'
'afi' '^[0-9]{1,8}$'
'mini' '^[0-9]{1,8}$'
'mfi' '^[0-9]{1,8}$'
'dini' '^[0-9]{1,8}$'
'dfi' '^[0-9]{1,8}$'
END
STATUS OFF
PROJECTION
"init=epsg:4326"
END
CONNECTIONTYPE postgis
CONNECTION "user=postgres password=pp dbname=mm host=host"
DATA "the_geom FROM (SELECT oid,geometry_columns
from table
where
time>='%aini%-%mini%-%dini% 00:00:00'
and time<'%afi%-%mfi%-%dfi%
00:00:00'
AS r USING UNIQUE oid USING SRID=4326"
El 10/05/12 13:24, abhishek bansal escribió:
> Hello All
> I am working on a project that require time as a dimension of data. I
> have gone through all documentation but I am not able to understand
> that how do I upload time data in server .map file. I have created
> simple map files and my server is working. What i need is same layer
> on different time should different dataset.
> plz help !!
> Thanks & Regards,
> Abhishek Bansal
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120510/55403453/attachment.html
