[mapserver-users] mapcache - problems on install
thomas bonfort
thomas.bonfort at gmail.com
Fri May 11 04:07:58 EDT 2012
That error message is related to apache, mapcache isn't even concerned
at this stage. What's in your apache configuration file? Did you add
the <Directory> entry containing the base path to mapcache.xml ?
thomas
On Fri, May 11, 2012 at 9:57 AM, Helen San Segundo Navazo
<hsansegundo at meteo.cat> wrote:
> Hi Thomas,
> I'm trying different calls but I'm sure I'm doing it wrong because I can't
> find a description how to construct the url call with the different params.
> http://localhost/mapcache/demo?LAYERS=vmap0&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG:4326&BBOx=-180,-90,180,90&WIDTH=700&HEIGHT=500&FORMAT=image/png
> What I obtain in my apache log is
> permission denied: access to /mapcache/demo denied
> the folders have permission for writting, I've put www-data as owner but the
> result is the same
> Could you help me to construct the url call if that is the problem?
> My mapcache alias is:
> MapCacheAlias /mapcache
> "/home/curs/Dearrollo/aplicaciones/mapserver-mapcache-18a50e2/mapcache.xml"
> the mapcache.xml is:
> <?xml version="1.0" encoding="UTF-8"?>
> <!-- see the accompanying mapcache.xml.sample for a fully commented
> configuration file -->
> <mapcache>
> <cache name="disk" type="disk">
> <base>/tmp</base>
> <symlink_blank/>
> </cache>
> <source name="vmap0" type="wms">
> <getmap>
> <params>
> <FORMAT>image/png</FORMAT>
> <LAYERS>basic</LAYERS>
> </params>
> </getmap>
> <http>
> <url>http://vmap0.tiles.osgeo.org/wms/vmap0</url>
> </http>
> </source>
> <tileset name="test">
> <source>vmap0</source>
> <cache>disk</cache>
> <grid>WGS84</grid>
> <grid>g</grid>
> <format>PNG</format>
> <metatile>5 5</metatile>
> <metabuffer>10</metabuffer>
> <expires>3600</expires>
> </tileset>
> <default_format>JPEG</default_format>
> <service type="wms" enabled="true">
> <full_wms>assemble</full_wms>
> <resample_mode>bilinear</resample_mode>
> <format>JPEG</format>
> <maxsize>4096</maxsize>
> </service>
> <service type="wmts" enabled="true"/>
> <service type="tms" enabled="true"/>
> <service type="kml" enabled="true"/>
> <service type="gmaps" enabled="true"/>
> <service type="ve" enabled="true"/>
> <service type="demo" enabled="true"/>
> <errors>report</errors>
> <lock_dir>/tmp</lock_dir>
> </mapcache>
> Thanks again,
> Helen
> El 10/05/12 15:38, thomas bonfort escribió:
>> given your configuration file, you have not disabled it. what url are
>> you trying to access the demo on ?
>> On Thu, May 10, 2012 at 3:16 PM, Helen San Segundo Navazo
>>> hi,
>>> deliberately I have not disabled the demo service, maybe in the
>>> installation
>>> I had to put any "--with" to enable it? is there any way to activate it?
>>> thanks
>>> El 10/05/12 14:14, thomas bonfort escribió:
>>>> please keep replies on the mailing list.
>>>> On Thu, May 10, 2012 at 2:07 PM, Helen San Segundo Navazo
>>>>> ok thanks, now seems that is really loaded the module. ([Thu May 10
>>>>> 13:21:24
>>>>> 2012] [notice] Apache/2.2.14 (Ubuntu) mod_fcgid/2.3.4
>>>>> mod-mapcache/0.5-dev
>>>>> configured -- resuming normal operations)
>>>>> The documentation talks about a demo, I can't find it. I have the
>>>>> mapcache.xml file with a sample with a basic layer. Could you tell me
>>>>> how
>>>>> test it, the url call?
>>>> from the fine manual:
>>>> If you have not disabled the demo service, you should now have access
>>>> to it on http://myserver/mapcache/demo
>>>> replace /mapcache/ with what you've set in MapCacheAlias
>>>> thomas
>>>>> thanks again,
>>>>> Helen
>>>>> <mapcache>
>>>>> <base>/tmp</base>
>>>>> <symlink_blank/>
>>>>> </cache>
>>>>> <getmap>
>>>>> <params>
>>>>> </params>
>>>>> </getmap>
>>>>> <http>
>>>>> </http>
>>>>> </source>
>>>>> <cache>disk</cache>
>>>>> <grid>WGS84</grid>
>>>>> <grid>g</grid>
>>>>> </tileset>
>>>>> </service>
>>>>> </mapcache>
>>>>> El 10/05/12 12:46, thomas bonfort escribió:
>>>>>> Sorry, pressed send too fast...
>>>>>> you must use
>>>>>> <IfModule mapcache_module>
>>>>>> <Directory /path/to/directory>
>>>>>> Order Allow,Deny
>>>>>> Allow from all
>>>>>> </Directory>
>>>>>> MapCacheAlias /mapcache "/path/to/directory/mapcache.xml"
>>>>>> </IfModule>
>>>>>> and not
>>>>>> <Location "/cgi-bin/">
>>>>>> SetEnv MAPCACHE_CONFIG_FILE
>>>>>> "/home/curs/Desarrollo/Aplicaciones/mapserver-mapcache-18a50e2/mapcache.xml"
>>>>>> </Location>
>>>>>> On Thu, May 10, 2012 at 12:43 PM, thomas bonfort
>>>>>> <thomas.bonfort at gmail.com> wrote:
>>>>>>> the instructions for running mapcache as an apache module are on the
>>>>>>> page you linked, more precisely:
>>>>>>> http://mapserver.org/trunk/mapcache/install.html#apache-module-specific-instructions
>>>>>>> thomas
>>>>>>> On Thu, May 10, 2012 at 12:33 PM, Helen San Segundo Navazo
>>>>>>>> Hi,
>>>>>>>> I'm new using mapcache. I've tried to install it following the
>>>>>>>> instructions
>>>>>>>> on http://mapserver.org/trunk/mapcache/install.html.
>>>>>>>> First
>>>>>>>> $./configure
>>>>>>>> $make
>>>>>>>> $sudo make install
>>>>>>>> and after the apache module
>>>>>>>> $sudo make install-module
>>>>>>>> $sudo ldconfig
>>>>>>>> On my httpd.conf I've added
>>>>>>>> </Location>
>>>>>>>> when I try to invoque mapcache in the apache log there is this
>>>>>>>> error:
>>>>>>>> /usr/lib/cgi-bin/mapcache: line 202: cd:
>>>>>>>> /home/curs/Desarrollo/Aplicaciones/mapserver-mapcache-18a50e2/cgi:
>>>>>>>> Not
>>>>>>>> a
>>>>>>>> directory
>>>>>>>> gcc: mapcache.c: No such file or directory
>>>>>>>> gcc: ../lib/.libs/libmapcache.so: No such file or directoryn[Thu May
>>>>>>>> 10
>>>>>>>> 11:57:23 2012] [error] [client 127.0.0.1] Premature end of script
>>>>>>>> headers:
>>>>>>>> mapcache
>>>>>>>> the directory exists and has permisions to access
>>>>>>>> Somebody knows how to solve it?
>>>>>>>> Thanks in advance,
>>>>>>>> Helen
>>>>>>>> _______________________________________________
>>>>>>>> mapserver-users mailing list
>>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
