[mapserver-users] mapcache - problems on install
Helen San Segundo Navazo
hsansegundo at meteo.cat
Fri May 11 05:30:29 EDT 2012
* I'm with apache 2.2.14
I've changed:
Require all granted
with:
Order allow,deny
Allow from all
I've restart apache
and the result is the same: permission denied: access to
/mapcache/demo denied
* I think the install-module went ok:
the result in the log was ([Thu May 10 13:21:24 2012] [notice]
Apache/2.2.14 (Ubuntu) mod_fcgid/2.3.4 mod-mapcache/0.5-dev
configured -- resuming normal operations)
is there any way to test that went succesfully?
* If I remove the <ifmodule> and restart apache I obtain the same
error permission denied: access to /mapcache/demo denied
I'm invoking:
http://localhost/mapcache/demo?LAYERS=vmap0&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG:4326&BBOx=-180,-90,180,90&WIDTH=700&HEIGHT=500&FORMAT=image/png
thanks,
Helen
El 11/05/12 11:15, thomas bonfort escribió:
> - Are you on apache 2.4 ? Require all granted will only work on 2.4
> - did you succesfully run "make install-module" in the mapcache folder ?
> - what happens if you remove the<IfModule mapcache_module> and
> </IfModule> lines ?
> On Fri, May 11, 2012 at 10:30 AM, Helen San Segundo Navazo
> <hsansegundo at meteo.cat> wrote:
>> In my httpd.conf I have:
>> <Directory "/home/curs/Desarrollo/Aplicaciones/mapserver-mapcache-18a50e2/">
>> Require all granted
>> </Directory>
>> MapCacheAlias /mapcache
>> "/home/curs/Desarrollo/Aplicaciones/mapserver-mapcache-18a50e2/mapcache.xml"
>> </IfModule>
>> El 11/05/12 10:07, thomas bonfort escribió:
>>> e<Directory> entry containing the base path to ma
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120511/6348196e/attachment.html
