[mapserver-users] nginx/fastcgi/mapserver
Peter Maes
thxftw at gmail.com
Fri May 11 05:47:08 EDT 2012
Ok, apparently i was using the wrong path when i fetched and build the
source from github :). Either way
MapServer version 6.1-dev OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ
SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
SUPPORTS=GEOS INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
And that seems to work perfectly :).
Thanks for your help.
2012/5/11 thomas bonfort <thomas.bonfort at gmail.com>
> On Fri, May 11, 2012 at 11:32 AM, Peter Maes <thxftw at gmail.com> wrote:
> > Hi,
> > Thanks again for your answer Thomas.
> > I have seen that issue report and I am using mapserver latest version
> (6.0.2
> > (which is what you meant? or is there an actual 6.2 somewhere)
> no, 6.2 is the one. You'll have to build from github master if you
> want to use it.
> > It does indeed keep working if i reference a good map and hammer F5.
> > Although: when i for instance call a wrong mapfile and hammer that it
> will
> > also kill the processes. Is there a workaround for this? Otherwise people
> > can just execute denial of service attacks on my mapserver.
> > We're already using nginx for static file hosting. It would be great if i
> > could get a production ready mapserver environment there as well.
> >> You might want to have a look at
> >> https://github.com/mapserver/mapserver/issues/3099
> >> tl;dr
> >> - mapserver fastcgi calls exit() when running in an error condition,
> >> which causes some fastcgi spawning managers to have issues
> >> - mapserver 6.2 (current git master) has been refactored to greatly
> >> minimize the exit() occurences (basically only on memory allocation
> >> errors)
> >> thomas
> >> On Fri, May 11, 2012 at 10:42 AM, Peter Maes <thxftw at gmail.com> wrote:
> >> > Hello,
> >> > I'm trying to run mapserver on nginx (fastcgi), but after 2 days
> booked
> >> > little success.
> >> > 1. I've compiled mapserv with fastcgi support and validated this
> >> > 2. I created a spawn-fcgi startup script based on this
> http://osgeo-org.1560.n6.nabble.com/Mapserver-on-nginx-td4226669.html
> >> > It now looks like this:
> >> > #!/bin/sh
> >> > MAPSERV_PORT=9001
> >> > USER=www-data
> >> > DAEMON=/usr/local/bin/mapserv
> >> > CHILDREN=5
> >> > # the -F switch of spawn-fcg does not work when the -n swich
> >> > # is set. using multiwatch instead
> >> > # see
> http://manpages.ubuntu.com/manpages/lucid/man1/spawn-fcgi.1.html
> >> > exec setuidgid $USER spawn-fcgi \
> >> > -a 127.0.0.1 \
> >> > -p $MAPSERV_PORT \
> >> > -u $USER \
> >> > /usr/bin/multiwatch -f $CHILDREN $DAEMON
> >> > In Nginx its called like this:
> >> > location /mapserver/ {
> >> > include /etc/nginx/fastcgi_params;
> >> > fastcgi_pass 127.0.0.1:9001;
> >> > fastcgi_param SCRIPT_FILENAME
> >> > /usr/local/run/spawnscript;
> >> > fastcgi_param PATH_INFO /usr/local/run/ spawnscript;
> >> > When i try to connect to /mapserver in my browser, i get an error
> >> > stating
> >> > 502 Bad gateway.
> >> > So i tried starting the spawn script
> >> > manually: /usr/local/run/spawnscript .
> >> > When i then try to connect using browser it works fine for a short
> >> > while. On
> >> > the console it logs this error:
> >> > Spawing child[0] failed, next try
> >> > Child[1] died, respawn
> >> > Child[2] died, respawn
> >> > Child[3] died, respawn
> >> > Child[4] died, respawn
> >> > Child[0] died, respawn
> >> > Spawing child[1] failed, next try
> >> > Spawing child[2] failed, next try
> >> > Spawing child[3] failed, next try
> >> > Spawing child[4] failed, next try
> >> > Child[1] died to often, not forking again
> >> > Child[2] died to often, not forking again
> >> > Child[3] died to often, not forking again
> >> > Child[4] died to often, not forking again
> >> > Child[0] died to often, not forking again
> >> > After which the process exits and I revert to the 502 Bad gateway.
> >> > What am I missing here? :).
> >> > Thanks for any tips. I'm not that experienced with spawn-fcgi.
> >> > _______________________________________________
> >> > mapserver-users mailing list
> >> > mapserver-users at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120511/b175b7c5/attachment-0001.html
