[mapserver-users] Re: Mapserver + mapcache + Google Map
mkrassovski
krassovskimb at ornl.gov
Fri May 11 08:32:25 EDT 2012
Thomas,
all I can see in apache log are lines like:
[Fri May 11 08:16:01 2012] [error] [client ] mapcache fcgi conf file:
/var/www/mapcache/mapcache.xml, referer:
http://cdiac5.ornl.gov/waves/underway/test_mapcache.html
[Fri May 11 08:16:02 2012] [error] [client ] mapcache fcgi conf file:
[Fri May 11 08:16:02 2012] [error] [client ] tile x=-1 not in [0,8[,
referer: http://cdiac5.ornl.gov/waves/underway/test_mapcache.html
[Fri May 11 08:16:47 2012] [error] [client ] mapcache fcgi conf file:
[Fri May 11 08:16:47 2012] [error] [client ] tile x=-1 not in [0,8[,
....... and so on
If I query wms server directly (without mapcache) it creates almost correct
images. In this case it doesn't matter what projection I use (900913 or
4326) to query wms , it produces the same result. You can see the image
here:
http://cdiac3.ornl.gov/waves/img/wms_900913.png
And this is what I have when I use mapcache:
http://cdiac3.ornl.gov/waves/img/mapcache_4326.png
Misha
View this message in context: http://osgeo-org.1560.n6.nabble.com/Mapserver-mapcache-Google-Map-tp4958439p4968271.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
