[mapserver-users] Re: Scale changes to mapserver 6.1-dev
Andy Colson
andy at squeakycode.net
Fri May 11 09:47:06 EDT 2012
The MAXSIZE map option may have gotten a new default. It used to be
2048, but lots of people have new super wide monitors and maps wont
render on them. I have had to add "MAXSIZE 4096" to all my mapfiles.
To return to the default, you might try adding: "MAXSIZE 2048" to the
top of your mapfile.
-Andy
On 5/11/2012 8:07 AM, Peter Maes wrote:
> When I run the mapfile with shp2img i get proper results.
> So in all likelyhood it will have to do with mode gmaps. I'll give a try
> with wms in the mean while.
> It seems as if for some reason i get the entire map rendered, for every
> tile requested.
> 2012/5/11 Peter Maes <thxftw at gmail.com <mailto:thxftw at gmail.com>>
> Hi,
> Did something change in regards to the scales? I took an existing
> mapfile config (that worked fine on mapserver 6.0) and ran that now
> with 6.1-DEV.
> However i get repeated messages stating:
> msLayerIsVisible(): Skipping layer (L1) because LAYER.MAXSCALE is
> too small for this MAP scale
> When I remove the layer, the layer gets drawn, however it does not
> match the scale of google maps.
> In fact, at a zoomed in level, i see my layer draw 6 times next to
> eachother (as you would have on google zoom 0-2).
> Best regards.
> mapserver-users at lists.osgeo.org
