[mapserver-users] cannot build svn mapserver with php-mapscript
Steve.Toutant at inspq.qc.ca
Thu May 17 11:17:38 EDT 2012
I successfully built mapserver (svn version) on SLES 11 SP1, but cannot
compile with php-mapscript. I get this error
/usr/lib64/gcc/x86_64-suse-linux/4.3/../../../../x86_64-suse-linux/bin/ld:
/usr/lib64/libxml2.a(error.o): relocation R_X86_64_32 against
`.rodata.str1.1' can not be used when making a shared object; recompile
with -fPIC
/usr/lib64/libxml2.a: could not read symbols: Bad value
collect2: ld returned 1 exit status
make[1]: *** [php_mapscript.so] Erreur 1
Here is the /configure options I used, and below the mapserver config I
get
Someone can help?
thanks
steve
make distclean
./configure --with-gdal=/usr/bin/gdal-config \
--with-httpd=/usr/sbin/httpd2 \
--with-wfsclient \
--with-wmsclient \
--enable-debug \
--with-curl-config=/usr/bin/curl-config \
--with-proj \
--with-png=/usr \
--with-tiff \
--with-gd=/usr \
--with-gif=/usr \
--with-jpeg=/usr \
--with-xpm=/usr \
--with-freetype=/usr/bin \
--with-threads \
--with-postgis=/usr/bin/pg_config \
--with-agg \
--with-php=/usr/include/php5 \
--with-ogr=/usr/bin/gdal-config \
--with-wfs \
--with-geos
MapServer is now configured for
-------------- Compiler Info -------------
C compiler: gcc -g -fPIC -Wall
C++ compiler: g++ -g -fPIC -Wall
Debug: -g
Generic NINT:
-------------- Renderer Settings ---------
OpenGL support:
zlib support: -DUSE_ZLIB
png support: -DUSE_PNG
gif support: -DUSE_GIF
jpeg support: -DUSE_JPEG
freetype support: -DUSE_FREETYPE
iconv support: -DUSE_ICONV
AGG support: internal
SVG Symbol support: -DUSE_AGG_SVG_SYMBOLS
Cairo (SVG,PDF) support:
KML support:
-------------- Support Libraries ---------
Proj.4 support: -DUSE_PROJ
Libxml2 support: -DUSE_LIBXML2
FriBidi support:
Curl support: -DUSE_CURL -DUSE_CURLOPT_PROXYAUTH
FastCGI support:
Threading support: -DUSE_THREAD
GEOS support: -DUSE_GEOS
XML Mapfile support:
XSLT support:
EXSLT support:
-------------- Data Format Drivers -------
PostGIS support: -DUSE_POSTGIS -DPOSTGIS_HAS_SERVER_VERSION
ArcSDE support:
OGR support: -DUSE_OGR
GDAL support: -DUSE_GDAL
Oracle Spatial support:
-------------- OGC Services --------------
WMS Server: -DUSE_WMS_SVR
WMS Client: -DUSE_WMS_LYR
WFS Server: -DUSE_WFS_SVR
WFS Client: -DUSE_WFS_LYR
WCS Server:
SOS Server:
-------------- MapScript -----------------
PHP MapScript: yes
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120517/337e0aa9/attachment.html
