[mapserver-users] error accessing PostGIS 2 layer
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu May 17 16:22:13 EDT 2012
Maybe you ("you" being anyone who recently hit this) can document your
steps around this upgrade in the new MapServer Wiki? :)
https://github.com/mapserver/mapserver/wiki
Thanks.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 12-05-17 4:58 PM, Puneet Kishor wrote:
> On May 17, 2012, at 2:20 PM, Donald Kerr wrote:
>> Run one of the ".sql" files in "\PostgreSQL\9.1\share\contrib\postgis-2.0"
>> to restore legacy funtions to PostGIS 2 e.g. "legacy.sql".
>> "legacy_minimal.sql" worked for me with my set up.
> phew! thanks! legacy_minimal.sql did it.
>> -----Original Message-----
>> From: mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Puneet Kishor
>> Sent: 17 May 2012 20:06
>> To: mapserver
>> Subject: [mapserver-users] error accessing PostGIS 2 layer
>> I migrated my data to PostGIS 2, and now I am getting the following error
>> (using the same mapfile as with PostGIS 1.5.3)
>> msPostGISLayerWhichShapes(): Query error. Error executing query:
>> ERROR: function
>> geomfromtext(unknown, integer) does not exist
>> LINE 1: ...e_geom FROM trees.range) a_view where the_geom &&
>> GeomFromTe...
>> HINT: No function matches the given name and argument types. You
>> might need to
>> add explicit type casts.
>> The offending query in the mapfile is
>> DATA "the_geom FROM (SELECT gid, species_id, species_color, the_geom
>> FROM trees.range) a_view USING UNIQUE gid USING srid=4326"
>> So, it seems the MapServer is using that line to construct its own query,
>> and that query is not compliant with PostGIS 2. Suggestions?
