[mapserver-users] Release of MapServer 6.0.3
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue May 22 13:11:50 EDT 2012
The MapServer team announces the release of MapServer versions 6.0.3.
No new functionality has been added. 6.0.3 is a maintenance release that
fixes a few issues found in since 6.0.2. The list of fixes since 6.0.2
is included at the end of this message.
Source and binary downloads:
The source code is available at:
http://mapserver.org/download.html
The binary distributions listed in the download page should be updated
shortly with binaries for the new 6.0.3 release.
-The MapServer Team
Version 6.0.3 (2012-05-18):
- Fix creation of a vector symbolObj in mapscript (#4318)
- Added coverage metadata in WCS (#4306)
- Adjusted WCS 2.0 GetCapbilities response (#4003)
- Ignore unknown requets parameteres in WCS 2.0 (#4307).
- Fixed mapscript is unusable in a web application due to memory leaks
(#4262)
- Fixed getFeature request with custom output format fails on filter
encoding (#4190)
- Fixed resolution when UoM changes in WCS 2.0 (#4283)
- Added missing DEFRESOLUTION parameter to msCopyMap() function (#4272)
- Fixed Python MapScript layerObj/classObj Error (#3940)
- Fixed WCS 2.0 axis order, offset vector, and origin (#4006, #4191)
- Fixed PHP MapScript opacity property of StyleObj no longer works (#3920)
- Added MS_CJC_* constants in PHP/MapScript (#4183)
- Fixed Memory leak with fribidi strings (#4188)
- Added missing properties in styleObj setter of PHP/MapScript (#3901)
