[mapserver-users] WFS GetFeature issue with MS4W
Eric Lemoine
eric.lemoine at camptocamp.com
Wed May 23 08:16:47 EDT 2012
Hi
I'm facing an issue with WFS GetFeature POST requests. This is with
MS4W 3.0.4 [1] (installed from the zip file), on Windows Server 2008
R2 Standard, 64-bit. The XML response returned by mapserv is
incomplete. The WFS GetFeature request is pretty basic, it just
includes a BBOX filter, see [2]. The end of the truncated response
looks like this:
<gml:featureMember>
<ms:mo9_immeubles>
<gml:boundedBy>
<gml:Box srsName="EPSG:21781">
<gml:coordinates>533307.287000,196036.205000
533337.719000,196067.143000</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<ms:msGeometry>
<gml:Polygon srsName="EPSG:21781">
<gml:outerBoundaryIs>
<gml:LinearRing>
<gml:coordinates>533333.496000,196036.205000
533337.719000,196056.953000 533325.629000,196060.658000
533312.183000,196067.143000 533307.287000,196043.126000
533315.968000,196042.982000 533317.853181,196042.846235
533319.724379,196042.579861 533321.572558,196042.184165
533323.388789,196041.661057 533325.164302,196041.013065
533326.890520,196040.243318 533328.559106,196039.355533
533330.162000,196038.354000 533333.496000,196036.205000
</gml:coordinates>
</gml:LinearRing>
</gml:outerBoundaryIs>
</gml:Polygon>
</ms:msGeometry>
<ms:url_terris_intra><a href="javascript:si
The same WFS GetFeature using GET results in a complete response, so
the issue really is related to POST. And when using MapServer on
*Linux* the same exact WFS GetFeature does result in a complete
response. On Windows the response headers include Transfer-Encoding:
"chunked". This has sounded suspicious to me first, because on Linux
MapServer does not return chunked responses. But I also get
Transfer-Encoding: "chunked" on Windows when using GET.
I have enabled debugging logs in MapServer [3], but this hasn't led
anywhere - the MapServer log file remains empty. Apache access.log
includes "Apache access.log: nesitnd1.ne.ch - - [23/May/2012:12:28:19
+0200] "POST /test_eric/mapserv? HTTP/1.1" 200 36825". This is
interesting to note that the response is a 200. And Apache error.log
does not reveal any MapServer crash (no "premature end of script" type
of thing).
Any suggestion for me?
Thanks.
[1] D:\ms4w\Apache\cgi-bin>mapserv -v
MapServer version 6.0.2 (MS4W 3.0.4) OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=KML SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CA
IRO SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPOR
TS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=P
OSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
[2] <wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs"
service="WFS" version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><wfs:Query
typeName="feature:mo9_immeubles"><ogc:Filter
xmlns:ogc="http://www.opengis.net/ogc"><ogc:BBOX><ogc:PropertyName>geom</ogc:PropertyName><gml:Box
xmlns:gml="http://www.opengis.net/gml"><gml:coordinates decimal="."
cs="," ts=" ">533104.74107143,195925.49107143
533327.24107143,196115.49107143</gml:coordinates></gml:Box></ogc:BBOX></ogc:Filter></wfs:Query></wfs:GetFeature>
[3]
CONFIG "MS_ERRORFILE" "D:/tmp/ms_error.txt"
DEBUG 5
CONFIG "CPL_DEBUG" "ON"
CONFIG "PROJ_DEBUG" "ON"
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
