[mapserver-users] mapcache_seed and DIM variables - order of
folders created
thomas bonfort
thomas.bonfort at gmail.com
Wed May 23 08:25:12 EDT 2012
No, it's not possible to do this at the moment. You can contact me
directly if you would like a quote on how much it would cost to have
this implemented.
regards,
thomas
On Wed, May 23, 2012 at 1:58 PM, Helen San Segundo Navazo
<hsansegundo at meteo.cat> wrote:
> hi ,
> after some problems installing mapcache now I can use it perfectly.
> I'm testing the mapcache_seed using dim variables and it works but when the
> folders are created I don't know if it's possible to create it in a
> determinate order.
> I have a mapfile that accepts runtime substitution variables (date, hour,
> minute)
> My mapcache.xml has defined the dimensions tag inside the tileset tag with
> the 3 variables
> if I execute mapcache as:
> sudo ./mapcache_seed -c /var/www/mapcache/mapcache.xml -t Meteosat_params -g
> WGS84 -z 0,3 -M 2,2 -D "minute=00" -D "hour=14" -D "date=20120314"
> I obtain:
> --Meteosat_params
> |-------WGS84
> |-------00 (minute)
> |-------14 (hour)
> |-------20120314 (date)
> It would be better for what I need if the folder order could be
> date-hour-minute instead of minute-hour-date
> I've tried to change the order in the mapcache_seed request but the result
> is always the same, anybody knows if it's possible to define the folder's
> order.
> Thanks in advance,
> Helen
> mapserver-users at lists.osgeo.org
