[mapserver-users] WFS GetFeature issue with MS4W
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed May 23 08:47:06 EDT 2012
Hello,
Actually this is a sporadic problem (difficult to duplicate) that has
existed for a while it seems, and has appeared on Windows and Linux.
Here are some related open tickets, please join the discussions there
and provide feedback:
https://github.com/mapserver/mapserver/issues/3977
https://github.com/mapserver/mapserver/issues/4039
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Eric Lemoine
> Sent: 23 May 2012 13:17
> To: mapserver-users
> Subject: [mapserver-users] WFS GetFeature issue with MS4W
> Hi
> I'm facing an issue with WFS GetFeature POST requests. This is with MS4W
> 3.0.4 [1] (installed from the zip file), on Windows Server 2008 R2 Standard,
> 64-bit. The XML response returned by mapserv is incomplete. The WFS
> GetFeature request is pretty basic, it just includes a BBOX filter, see [2].
> The end of the truncated response looks like this:
> <gml:featureMember>
> <ms:mo9_immeubles>
> <gml:boundedBy>
> <gml:Box srsName="EPSG:21781">
> <gml:coordinates>533307.287000,196036.205000
> 533337.719000,196067.143000</gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
> <ms:msGeometry>
> <gml:Polygon srsName="EPSG:21781">
> <gml:outerBoundaryIs>
> <gml:LinearRing>
> <gml:coordinates>533333.496000,196036.205000
> 533337.719000,196056.953000 533325.629000,196060.658000
> 533312.183000,196067.143000 533307.287000,196043.126000
> 533315.968000,196042.982000 533317.853181,196042.846235
> 533319.724379,196042.579861 533321.572558,196042.184165
> 533323.388789,196041.661057 533325.164302,196041.013065
> 533326.890520,196040.243318 533328.559106,196039.355533
> 533330.162000,196038.354000 533333.496000,196036.205000 </gml:coordinates>
> </gml:LinearRing>
> </gml:outerBoundaryIs>
> </gml:Polygon>
> </ms:msGeometry>
> <ms:url_terris_intra><a href="javascript:si
> The same WFS GetFeature using GET results in a complete response, so the
> issue really is related to POST. And when using MapServer on
> *Linux* the same exact WFS GetFeature does result in a complete response. On
> Windows the response headers include Transfer-Encoding: "chunked". This has
> sounded suspicious to me first, because on Linux MapServer does not return
> chunked responses. But I also get
> Transfer-Encoding: "chunked" on Windows when using GET.
> I have enabled debugging logs in MapServer [3], but this hasn't led anywhere
> - the MapServer log file remains empty. Apache access.log includes "Apache
> access.log: nesitnd1.ne.ch - - [23/May/2012:12:28:19
> +0200] "POST /test_eric/mapserv? HTTP/1.1" 200 36825". This is
> interesting to note that the response is a 200. And Apache error.log does
> not reveal any MapServer crash (no "premature end of script" type of thing).
> Any suggestion for me?
> Thanks.
> [1] D:\ms4w\Apache\cgi-bin>mapserv -v
> MapServer version 6.0.2 (MS4W 3.0.4) OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=KML SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CA IRO SUPPORTS=FREETYPE
> SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPOR TS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
> INPUT=JPEG INPUT=P OSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> [2] <wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs"
> service="WFS" version="1.0.0" xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><wfs:Query
> typeName="feature:mo9_immeubles"><ogc:Filter
> xmlns:ogc="http://www.opengis.net/ogc"><ogc:BBOX><ogc:PropertyName>geom</ogc
> :PropertyName><gml:Box
> xmlns:gml="http://www.opengis.net/gml"><gml:coordinates decimal="." cs=","
> ts=" ">533104.74107143,195925.49107143
> 533327.24107143,196115.49107143</gml:coordinates></gml:Box></ogc:BBOX></ogc:
> Filter></wfs:Query></wfs:GetFeature>
> [3]
> CONFIG "MS_ERRORFILE" "D:/tmp/ms_error.txt"
> DEBUG 5
> CONFIG "CPL_DEBUG" "ON"
> CONFIG "PROJ_DEBUG" "ON"
