[mapserver-users] Tiles problem
Lucero, Gastón (SITRACK)
gaston.lucero at sitrack.com
Wed May 23 07:25:21 PDT 2012
Hi, i have this problem when i generate tiles with mapscript using java
or php.
My .map principal
MAP
NAME "Map
STATUS on
SIZE 256 256
EXTENT -20037508 -20037508 20037508 20037508
UNITS meters
IMAGETYPE agg
SHAPEPATH "data"
FONTSET "/font/fonts.fnt"
SYMBOLSET "/symbols.sym"
IMAGECOLOR "#b3c6d4"
OUTPUTFORMAT
NAME agg
DRIVER agg/png
IMAGEMODE rgb
FORMATOPTION "PALETTE_FORCE=TRUE" #es incompatible con la
opcion anterior
FORMATOPTION
"PALETTE=/var/www/localhost/htdocs/rest/map/palette/map.palette"
MIMETYPE "image/png"
END
INCLUDE routes.map
END #map
And routes.map
MAP
LAYER
NAME routes
STATUS on
TYPE line
DATA "from postgisDB"
CLASSITEM "routestypegroupid"
LABELITEM "name"
MAXSCALEDENOM 14062500
MINSCALEDENOM 0
TOLERANCE 10
CLASS # Level 2
EXPRESSION /^4*$/
MAXSCALEDENOM 13732
MINSCALEDENOM 6867
STYLE
WIDTH 4
COLOR "#ffffff"
OUTLINECOLOR "#a09686"
OUTLINEWIDTH 1
END
LABEL
FONT sans
TYPE truetype
SIZE 7
COLOR "#000000"
OUTLINECOLOR "#ffffff"
MINDISTANCE 100
BUFFER 5
PARTIALS false
ANGLE follow
OUTLINEWIDTH 3
END
END
END
Thanks.
Disclaimer:
This email and any attachments thereof may contain confidential, privileged, proprietary, or otherwise private information. This email is intended solely for the use of the individual to whom it is addressed. If you are not the intended recipient of the email and its attachments please inform the sender immediately and do not disclose the contents to any other person, use it for any purpose or store or copy the information in any way and delete this e-mail and its attachments from your system. Any views or opinions expressed are solely those of the author.
Name: erro tiles.gif
Type: image/gif
Desc: erro tiles.gif
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120523/90bcb1d9/errotiles.gif
