[mapserver-users] some help on basic template (a beginner question)
Antonio Rodríguez
antonio.raju at gmail.com
Fri May 25 02:04:26 PDT 2012
I've been following the beginners tutorial and after searching the
archives (probably not so extensively) I couldn't find what I'm doing
wrong. I had arrived just at example1-9 and I can't find the way to
match my file.map to my index.html. The webserver is working fine. I'm
able to execute my file.map but when I try to visualise and execute a
personal version of example1-9 I always got stuck at this point:
msLoadMap(): Regular expression error. MS_DEFAULT_MAPFILE_PATTERN
validation failed. msEvalRegex(): Regular expression error. String
failed expression test.
My computer and files configuration are :
/etc/apache2/sites-available/default
<VirtualHost *:80>
ServerAdmin webmaster at localhost
ServerName cordillera
DocumentRoot /home/admin-root/cordillera
(rest omitted)
/etc/hosts
127.0.0.1 cordillera
File structure:
/datos_mapserver (.shp and .tiff files)
/tmp
/ms_tmp
lagos_rios_dem.map
cat index.html (is just a modification of example1-9.html)
<!--mapserver template-->
<html>
<head>
<title>MapServer Cordillera</title>
</head>
<body bgcolor="#FFFFFF">
<center><h2>MapServer Cordillera Application (ms v5.4)</h2></center>
<p><hr><p>
<!-- START OF MAPSERVER FORM -->
<form name="mapserv" method="GET" action="/cgi-bin/mapserv">
<!-- HIDDEN MAPSERVER CGI VARIABLES -->
<input type="hidden" name="map" value="[map]">
<input type="hidden" name="imgext" value="[mapext]">
<input type="hidden" name="imgxy" value="[center]">
<input type="hidden" name="zoom" value="0">
<input type="hidden" name="layer" value="relieve">
<input type="hidden" name="layer" value="aster-dem">
<input type="hidden" name="mode" value="browse">
<div align="center">
<table border="1" cellpadding="0" cellspacing="0">
<tr>
<td>
<!-- THE INTERACTIVE, DYNAMICALLY CREATED MAP -->
<input type="image" name="img" src="[img]"
width="400" height="300">
</td>
</tr>
</table>
</div>
</form>
<!-- END OF MAPSERVER FORM -->
</form>
<p><hr>
<table width="100%"><tr><td align="right">This site running
MapServer v. 5.4</td></tr></table>
</body>
</html>
cat lagos_rios_dem.map
MAP
IMAGETYPE PNG24
EXTENT -78 -10.5 -76.4 -8.25
SIZE 700 1000
SHAPEPATH "datos_mapserver"
IMAGECOLOR 255 255 255
WEB
TEMPLATE 'index.html'
IMAGEPATH '/home/admin-root/cordillera/tmp/ms_tmp'
IMAGEURL '/ms_tmp/'
END
LAYER
NAME relieve
DATA "mapa_de_relieve"
STATUS OFF
TYPE RASTER
OFFSITE 65 73 72
TRANSPARENCY 80
END
LAYER
NAME aster-dem
DATA "mapa_de_color"
STATUS OFF
TYPE RASTER
OFFSITE 65 73 72
TRANSPARENCY 70
CLASS
EXPRESSION ([pixel] >= 5479 AND [pixel] < 6800)
STYLE
COLORRANGE 250 250 255 255 255 255
DATARANGE 5479 6800
END
END
END
LAYER # Lagos
NAME lagos
DATA lagos
STATUS OFF
TYPE LINE
TRANSPARENCY 60
CLASS
NAME "Lagos"
STYLE
COLOR 0 0 232
END
END
END
LAYER
NAME rios
DATA rios
STATUS OFF
TYPE LINE
TRANSPARENCY 60
CLASS
NAME "Rios"
STYLE
COLOR 0 0 200
END
END
END
END
Thanks in advance!
Antonio
