[mapserver-users] OGRVRT Data Sources and SQL server
Robert Sanson
Robert.Sanson at asurequality.com
Mon May 28 14:52:49 PDT 2012
Hi Chris
I am successfully using OGR with SQL-Server with SQL authentication. This is what I do:
Say I want to plot farm gates. I have a System DSN datasource set up in ODBC say called "MYDSN" with SQL Server authentication.
I create a farmgates.ovf file containing:
<OGRVRTDataSource>
<OGRVRTLayer name="farmgates">
<SrcDataSource>ODBC:user/passwd at MYDSN</SrcDataSource>
<SrcLayer>vw_farmgates</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>EPSG:2193</LayerSRS>
<GeometryField encoding="PointFromColumns" x="x_coord_nztm" y="y_coord_nztm"/>
<FID>point_location_id</FID>
</OGRVRTLayer>
</OGRVRTDataSource>
In my map file I have:
LAYER
NAME "farmgates"
GROUP "FMS"
CONNECTION "./farmgates.ovf"
CONNECTIONTYPE OGR
DATA "farmgates"
#FILTER "WHERE feature_type_id = 11 and farm_id = '%farmid%'"
SIZEUNITS PIXELS
STATUS ON
DUMP TRUE
# query templates for HTML-based queries
# responds to OGC:WMS request=GetFeatureInfo......&info_format=text/html
HEADER ../templates/farmgates_query_header.html
TEMPLATE ../templates/farmgates_query_body.html
# fuzziness for querying
TOLERANCE 5000
TOLERANCEUNITS METERS
TYPE POINT
UNITS METERS
# scale range
MAXSCALE 250000
MINSCALE 750
LABELMAXSCALE 100000
LABELMINSCALE 1
LABELCACHE on
LABELITEM 'reference_code'
CLASS
STYLE
COLOR 138 43 226
OUTLINECOLOR 0 0 0
SIZE 13
SYMBOL "triangle"
END
LABEL
TYPE truetype
FONT "arial"
SIZE 10
POSITION ur
#ANGLE auto
OUTLINECOLOR 235 235 235 #--Halo
COLOR 0 0 0
#MINDISTANCE 50
#MINFEATURESIZE 10
BUFFER 2
#SIZE small
END #LABEL
END #CLASS
METADATA
"wms_group_title" "FMS"
"wms_name" "farmgates"
"wms_title" "farmgates"
"wms_abstract" "These are farmgates in NZTM"
"wms_keywordlist" "AgriBase"
#"wms_server_version" "1.1.1"
"wms_srs" "EPSG:2193"
"wms_extent" "1114412.940 4793178.168 2089186.204 6190213.601"
"wms_dataurl_format" "text/HTML"
"gml_include_items" "all"
"gml_exclude_items" ""
"ows_include_items" "all"
"ows_exclude_items" ""
"wms_exceptions_format" "application/vnd.ogc.se_xml"
END
END #farmgates
Regards,
Robert
>>> Chris Jackson <webturtles at gmail.com> 29/05/2012 3:01 a.m. >>>
Hi all
Has anyone got much experience of using OGRVRT Data Sources in Windows with
SQL server system DSNs? I am having an issue with system DSN connection
type (windows authentication will work fine and proceses the table fine,
sql authentication - get not trusted connection (both authentication types
enabled in instance)) when testing via ogrinfo commandline.
Then if I take the working code forward then I can't render the layer in a
map output via say shp2img commandline or final map application. Map code
below:
LAYER
NAME "virtual"
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION
"<OGRVRTDataSource>
<OGRVRTLayer
name='omreg1'>
<SrcDataSource>ODBC:@omreg1</SrcDataSource>
<SrcSQL>SELECT * FROM
dbo.Site</SrcSQL>
<GeometryField encoding='PointFromColumns' x='SiteLong'
y='SiteLat'/>
</OGRVRTLayer>
</OGRVRTDataSource>" # the name and path to the virtual.ovf file, relative
to shapepath may work?
DATA "omreg1"
TEMPLATE void
PROJECTION
"init=epsg:4326"
END
METADATA
"wms_srs" "4326"
"wms_title" "virtual"
END
SIZEUNITS PIXELS
STATUS ON
TOLERANCE 0
TOLERANCEUNITS PIXELS
UNITS METERS
CLASS
NAME "Virtual"
COLOR 255 0 0
OUTLINECOLOR 255 0 0
SYMBOL 'kreuz4'
SIZE 6
END # Class
END
My version of mapserver is a little old (5.6.1). I wonder whether I need
to set any extra SQL related env variables.....
Any assistance much appreciated!
Thanks
Chris
This email and any attachments are confidential and intended solely for the addressee(s). If you are not the intended recipient, please notify us immediately and then delete this email from your system.
This message has been scanned for Malware and Viruses by Websense Hosted Security.
www.websense.com
